603,978 active members*
2,144 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Tree spindle question
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Oct 2007
    3
    figured out spindle lock problem. my tree, which has automatic spindle drive (? correct description) was missing the small pins underneath the knurled knob which when tightened causes spindle to automatically go down or up. it had become locked in automatic mode. i was not aware the machine had this feature. no problem now
  2. #22
    Oct 2007
    3
    Quote Originally Posted by daveys View Post
    i think you have a version of the same problem i have. ive just posted an extension to further explain my situation, but its not up yet. hard to find people that know what`s up. locally anyway. did you get spindle problem fixed?
  3. #23
    Mar 2008
    7
    Spindle Grease
    Quote Originally Posted by treethor View Post
    Guys, the spindle bearings are greased and their is no seal at the bottom of the spindle.
    Dan from Tree Tech the service, engineering, applications of what used to be Tree Machine Tool. Any questions call me. 262-781-9804
    Dan
    Do you mean that the spindle bearing need regular greasing? How is this done? There is no info in the manual that I have.
    What is the toggle switch on the side of the power cabinet, next to the drive cabinet for?
    Rob
Page 2 of 2 12
  1. Tree vertical mill - question
    By pendentive in forum Uncategorised MetalWorking Machines
    Last Post: 12-04-2009, 03:03 AM
  2. Question about spindle on SX3
    By Kevin Harpham in forum Syil Products
    Last Post: 01-02-2007, 09:51 PM
  3. Tree 750 Spindle Orientation
    By CFMold in forum Tree
    Last Post: 12-11-2006, 07:41 PM
  4. R8 Spindle Question:
    By CROSSHATCH in forum CNC Tooling
    Last Post: 09-08-2006, 08:01 PM
  5. spindle lock question
    By Scott-M in forum MetalWork Discussion
    Last Post: 12-01-2004, 02:18 AM
