603,954 active members*
3,301 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Tree spindle question
Page 1 of 2 12
Results 1 to 20 of 23
    Hello folks,
    I'm in the market for a used US made manual mill and have heard great things about Tree mills. Currently I'm looking at a couple of 2UVR mills. One has the double taper Tree style collet holder. The other one doesn't appear to have this holder (it might just be missing the collet nut, but it's hard to tell from the photos) and the owner isn't a machinist nor does he have any info on the mill. The mills are not anywhere near where I live so I'll have to commit without inspecting them beforehand.
    Finally getting to my question...did all 2UVR mills use the Tree style collets? And, if this mill doesn't have the holder and/or nut are these readily available?
    Thanks for the info!
    Jun 2006
    4
    http://www.3sincorporated.com/index.htm
    These guys would probably have a collet nut for a 2UVR. If not, I have an old one that I would sell you.
    As far as I know all 2UVRs are Z collets (the double angle collet that you are talking about). I have been using my 2UVR for 5 years and I like the collets. They are easier to change than a R8 collet and they hold long, double end mills because they don't have a drawbar like an R8. The only problem is that the collets are hard to find. Mine are pretty worn out and are starting to get stuck in the spindle. I'm considering having my spindle machined to accept ER collets, which are similar but easy to buy new out of any machine tool catalog and also hold a wider range of sizes.
    Hey Todd, thanks for the info. I'm watching a couple of 2UVRs and hopefully I'll be bringing one home soon. I'll keep you in mind if the collet nut is in fact missing.
    Tree Collets
    The Type Z collets are out there but the popular sizes are indeed hard to find.
    1/4" 3/8" 1/2"... they're tough but everything else is easy, on the other had they can get expensive.
    But here's the great thing... you can MAKE THEM! ahahahh try making an R8! well, you wouldnt have to since they're a dime a dozen....
    but anyway. making a type Z is easy... Here's a pic when I made my first one:
    on the left is a 1/8" that I got with the machine, on the right is a 1/2" that I made. Ordinary cold-rolled steel. works perfect.
    Dec 2006
    what about an endmill holder? which one will work? i need to use a 1 3/4" roughing bit in my tree mill.
    the biggest collet i have is 3/4" and i cant find a 1 3/4" roughing bit with a 3/4" shank
    Find a smaller roughing bit I guess... 3/4" is the biggest shank that will fit in the 2UVR as far as I know.
    Nov 2005
    440
    Stenson Voyager is correct, even the 200 Tradesman only will chuck a a 3/4" shank..I have turned the shank down in my lathe to accomodate, even a couple of R8's I had on hand. They work fine,the Tree spindle is tuff, to say the least..
    Adobe (old as dirt)
    More great info guys, thanks!
    My new-to-me 2UVR is sitting in my pickup waiting for the forklift guy to show up.
    I can't wait to get it up and running!
    Sweet! Send us pics.
    Here's a link to mine:
    http://www.stinsonvoyager.com/Tree%20Mill.htm
    I'll post some once it's in the shop. And perhaps after I do some clean up, repainting, etc. It's of similar vintage to yours, but no where near as nice condition as yours! It came from GM's Saginaw plant, steering division and was rescraped in 1979. I'm guessing it sat mostly since then.
    Starting to put her back together
    I'm finally making some progess! I posted some pics on myspace. Here's a link:
    http://viewmorepics.myspace.com/inde...lbumId=1104056
    oooooooo
    Pretty!
    Oct 2007
    3
    i have a tree 2uvr. spindle is not moving up and down. it has been getting harder and harder to move until finally it is locked in position. what do i need to do.
    Oct 2007
    3
    i think you have a version of the same problem i have. ive just posted an extension to further explain my situation, but its not up yet. hard to find people that know what`s up. locally anyway. did you get spindle problem fixed?
    Feb 2007
    3
    I read sometime ago that Tree made something so that
    you could use a 1" shank in the spindle. Don't remember
    where I saw it.
    BTW I have two 2UVR's.
    Lee
    Oct 2007
    5
    Tree 1" weldon shank
    My Tree was kind enough to have a 1" shank adaptor when I bought it. It's an extension affair that replaces the collet nut and extends about 3" down.Has one 3/8 allen key set screw to hold the tool.
    Works great for larger tooling.
    On the other hand, the table drive was long gone. Would be nice to have!
    Rich.
  17. #17
    Feb 2007
    3
    Is there any way you could post a picture of that
    adaptor. I would like to make one.
    Lee
  18. #18
    Feb 2007
    3
    Does anyone know if there are seals or 'O'rings in the 2UVR
    spindle. Mine leaks. Not gallons but enough to throw oil all
    over the floor and me. Thanks.
    Lee
  19. #19
    Oct 2007
    5
    Lee, will try.Need to take picture and I've never posted pics before.
    About oil from spindle...mine is the same leaker..I try to clean with a rag before I start the spindle. I've ruined more than one shirt. richard.
  20. #20
    Mar 2008
    4
    Guys, the spindle bearings are greased and their is no seal at the bottom of the spindle.
    Dan from Tree Tech the service, engineering, applications of what used to be Tree Machine Tool. Any questions call me. 262-781-9804
Page 1 of 2 12
  1. Tree vertical mill - question
    By pendentive in forum Uncategorised MetalWorking Machines
    Last Post: 12-04-2009, 03:03 AM
  2. Question about spindle on SX3
    By Kevin Harpham in forum Syil Products
    Last Post: 01-02-2007, 09:51 PM
  3. Tree 750 Spindle Orientation
    By CFMold in forum Tree
    Last Post: 12-11-2006, 07:41 PM
  4. R8 Spindle Question:
    By CROSSHATCH in forum CNC Tooling
    Last Post: 09-08-2006, 08:01 PM
  5. spindle lock question
    By Scott-M in forum MetalWork Discussion
    Last Post: 12-01-2004, 02:18 AM
