603,930 active members*
4,984 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Trim One not working on this corner (see file) EDIT: different Z planes. How to fix?
Results 1 to 5 of 5
    Mar 2006
    177
    I can't for the life of me figure out why "Trim one" or any other trim I've tried isn't working on this corner (see the attached file made in V23). Any ideas what's happening here?
    Attached Files Attached Files
    Mar 2006
    177
    Ok... I think I figured it out. I clicked measure and it looks like the Geometry (imported from Corel) is on different Z heights. Don't know why this is.
    Any ideas how to fix this?
    EDIT: actually I think I did most of the offending geometry in BobCAD. Not sure why it's showing a tilt in the Z plane. It should all be at Z=0 as I drew it.
    So that's the next question... how in the world did the geometry get botched up. It looks like everything's got some weird Z tilt now. It should all be at Z=0 as I drew it.
    Apr 2009
    3376
    Time to re-draw.This time use point coordinates and put 3 points,that would be one point for the end of each line and one point for the place of intersection.Now use line join.Or if you like where each line is in the x and y axis you could do a point end on the lines,then do a measure on each point and find where the z is at then translate to zero.After doing that to all 4 points,do a line join,then trim the intersection.
    Mar 2012
    1570
    You do have another option. Sometimes you'll be working with geometry that is not flat on a plane, so you ned to flatten it.
    This is easy to do, create a surface on the xy plane and project the geomerty onto that surface. This will flatten your geomerty so its all on z0.
    I try to create a video for this tomorrow.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Dec 2008
    4545
    Trim Screen - YouTube
    Trim Screen. For trimming things non-planar from a planar UCS.
    But, if the drawing was supposed to be all at one planar level, then what Al said!
  1. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  2. More trim
    By cncadmin in forum EnRoute
    Last Post: 08-04-2012, 08:00 AM
  3. Solidworks file not working
    By smcdonn in forum BobCad-Cam
    Last Post: 02-23-2011, 11:17 PM
  4. Trim
    By john_mccarron in forum EdgeCam
    Last Post: 11-28-2007, 01:42 AM
  5. working w/ iges file
    By tom@wave-l in forum Mastercam
    Last Post: 07-13-2005, 06:57 PM
