603,341 active members*
4,885 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Trouble with Multiple Retracts on Peck drill cycles
Results 1 to 13 of 13
    Oct 2011
    Hi, I'm a little new to all this, so if my terminology or placement is stupid, let me know.
    I work on a Haas mini mill, using NX7.5 to make my code. all the parts i make are fairly irregular bodies, single part, double sided. One of the things i always need is a hole array in the part, usually offset from the edges by a bit, and so on. i've figured out how to set up the holes specifically in the part, and assign them to be cut, but currently, my machine only reads the first retract plane and ignores the rest, leading to it crashing. i've got a few solutions for this, none of which are particularly elegant. I'm wondering if there's a mill setting to recognize additional retract planes, or, alternately, if i need to rewrite my post.
    Thanks in advance!
    Jan 2005
    15362
    Zagadka60
    Post the code you are trying to use, we will have a better idea of what may be happening, G83 or G73 work fine on the Haas machines
    Mactec54
    Jul 2005
    12177
    You need to check that your CAM output has G98 Initial Point Return, not G99 R Plane Return and also make sure it has not included a move close to the surface just before the drill cycle.
    Oct 2011
    Here's some of the code i've been using, as far as i can tell, it looks appropriate to what you're saying, but i'm not certain now. I'm thinking maybe my post has some problems on this front.
    G40 G17 G90 G70
    T07 M06
    M01
    G1 X4.3448 Y2.5955 F200. S5500 M03
    G43 G0 Z-.4133 H07
    G83 Z-.8901 R-.4133 F30. Q.0197
    G83 X3.6312 Y2.2628 Z-.5137 R-.0503 Q.0197
    G83 X2.9175 Y1.93 Z-.3317 R-.0018 Q.0197
    G83 X2.2039 Y1.5972 Z-.6642 R-.2381 Q.0197
    G83 X1.4903 Y1.2645 Z-.9671 R-.5757 Q.0197
    G83 X1.1575 Y1.9781 Z-.9518 R-.5255 Q.0197
    G83 X1.8711 Y2.3108 Z-.6142 R-.1897 Q.0197
    G83 X2.5848 Y2.6436 Z-.4385 R-.0224 Q.0197
    G83 X3.2984 Y2.9764 Z-.747 R-.1662 Q.0197
    G83 X2.252 Y3.3572 Z-.8812 R-.3656 Q.0197
    G83 X1.5384 Y3.0245 Z-.9807 R-.4105 Q.0197
    G83 X.8247 Y2.6917 Z-1.1633 R-.6297 Q.0197
    G80
    M05
    G28
    It seems to ignore the R call after the first one. in this case, the move after the first hole crashed into the part.
    Thanks for your replies.
    Dec 2003
    24260
    Not sure if this helps in this case, but something that may prove useful at some time.
    Al.
    Attached Thumbnails Attached Thumbnails Drill_peck_macro.jpg   Drill_peck_macro2.jpg
    Albert E.
    Oct 2011
    That's close, but i don't have a regular enough surface to get a regular formula out of it. thanks though! If i'm reading that right, it lets you mathematically progress through the holes, and i'm mostly working with surfaced facet bodies. if i'm reading that completely wrong, let me know.
    Jan 2005
    15362
    Zagadka60
    You Have to have in this case a G99 to actervate the R value
    So you need it to be G83G99-------
    A G98 does not use the R set value It will return the Z to it's set hight in the program which you dont have one you have all negitive Z settings & R values so need a G99
    Attached Files Attached Files
    Mactec54
    Oct 2011
    Brilliant! that's exactly what i was looking for, Mactec54, you're wonderful. thanks a million.
    Feb 2006
    1792
    Quote Originally Posted by Zagadka60 View Post
    G43 G0 Z-.4133 H07
    Logically, R-point should lie below the initial tool level (Z-position).
    Therefore, change Z-.4133 to, say, Z.05 (I am assuming that Z0 lies on the top surface of the workpiece).
    Moreover, if the R-point in below the top surface, you need to retract up to initial tool level (use G98).
    Jan 2005
    15362
    sinha_nsit
    I think you miss understand what Zagadka60 is trying to do
    Each R value is clearance too the next hole, So to actervate the R he needs to use a G99
    His hole starting points are at different heights
    He could do with a seperate G0Z3. at the end of the program, the G28 could move all 3 axes at the same time & he could crash into something before the tool is clear
    Mactec54
    Feb 2006
    1792
    I thought Haas is nearly same as Fanuc. So, what I said may not apply on Haas.
    Moreover, I have possibly not clearly understood what Zagadka60 is trying to do.
    Sep 2010
    1230
    Quote Originally Posted by sinha_nsit View Post
    Hi Sinha,
    You're correct in that the HAAS G83 cycle is nearly the same as the Fanuc cycle, but with a few more features. The HAAS G83 cycle also has the following features that are not available in the Fanuc equivalent
    I Size of first peck depth (if Q is not used)
    J Amount reducing each peck after first peck depth (if Q is not used)
    K Minimum peck depth (if Q is not used)
    P Dwell time at Z-depth
    HAAS also has a setting (setting 52) that allows a distance to be set above the R plane for the tool to retract to after each peck. This allows the R plane to be set close to the work surface, yet has the drill retract well clear of the hole for better swarf evacuation. The difference being is that the drill will Rapid from the Initial Level to the R plane set close to the work surface, thus not cutting a lot of fresh air, but when it retracts after each peck, it does so to whatever value is set in Setting 52 above the R plane.
    G98 and G99 work in the same way as the Facuc control. Both are model G codes, with G98 being the default.
    What you stated in your penultimate post would have worked, particularly with a an irregular surface. Setting an initial level above the highest point of the irregular surface, and using G98 would ensure that the tool would clear any obstacle when moving between holes, and the individual R planes could be included in each hole definition so that excessive air cutting did not occur.
    Effectively, the OP has an initial level that is lower than most of the R planes. Because he initially omitted both G98 and G99, the default G98 would have forced the tool to return to Z-0.4133 before moving to the next hole location. Given that the initial level is lower than all bar 3 of the Zagadka60's R plane coordinates, and his comments in the original post regarding crashing, the drill must still be below the top surface of at least some of the holes. In my opinion using G99 as a fix is a bit of a Fudge, and your suggestion is the more appropriate and elegant resolve.
    Regards,
    Bill
    Dec 2012
    Wink Hole avoidance
    If I understand what your trying to do. Is go from 1 hole to the next without crashing into the part. In NX 7.5 you need to enter an avoid distance.
    Hope this helps.
  1. G83 Peck Drill on Fanuc 18-T
    By JerryH in forum G-Code Programing
    Last Post: 07-10-2024, 02:34 PM
  2. What do I need to peck drill in wood?
    By 777funk in forum BobCad-Cam
    Last Post: 02-12-2011, 07:19 PM
  3. different peck cycles?
    By C5turbo in forum Fanuc
    Last Post: 11-06-2008, 12:03 PM
  4. To Peck drill or not to peck dril.....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 08-23-2008, 05:33 PM
  5. Peck Cycles and Simulate
    By bill south in forum BobCad-Cam
    Last Post: 12-26-2006, 12:06 AM
