Need help with uninstall/re-install of Bobcad V24.
Running Windows XP, all latest updates and video drivers. The computer hung up on an un-related issue. I finally had to hard shut down the compter. After Check disc fixed all the issues Bobcad V24 will take 15 minutes at 100 CPU to get started. After that it works OK. I still have V23 loaded and it starts fine.
I've tried un-install, then re-install. No better.
Then, I un-installed. Deleted all V24 folders and checked the registry. I found no entries for V24. Then I re-installed.
I tried to start V24 this morning, I get to the beginning of startup and it again pulls 100% cpu and takes 15 minutes to get started.
Any other suggestions?
Thanks in adavance
Robert
