Okay. Well had a crash (wasn't me!!) and so far I aligned the turret and I got the turrett to index and locate properly. I am also running the machine and it works.
The only thing when I go to zero return individual A axis. It unlocks the turrett. Attempts to locate then misalligns the turrent a few degrees below the coolant locator.
(The way I am able to get it to allign is M43, then jogging the A axis into place, M44, then run it from there)
Also, I have played with the collar on the servo motor and did a "z channel only" and zero returned the A axis servo then clamped the servo.
What gives??
