I need the following part made, I only need one and I don't want to spend several hundred dollars on one. The tolerances are +/- .01, however there are some measurements that don't have to be exact. The fillets just need to be a rounded edge, I didn't want a sharp edge so whatever is easiest for machining purposes. The most important part is the top piece, that gets clamped to a fitting for welding, this is going to be a heat sink to prevent warping. The hole going through will provide argon coverage for back purging.
Material needs to be 6061 aluminum.
If you have a piece of scrap that's not quite this length, that will work. Like I said, the most important part is the top two inches.
If you need a certain file type let me know I can send it your way. Fastest way to get a hold of me is email - [email protected]
Thanks!!
