603,893 active members*
3,944 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Turning simulation throws exception
Results 1 to 5 of 5
    Jul 2009
    56
    I build a profile using DCAD, set up the NC profiles, and go to the turning module.
    There, I setup the machine type, all tools, and turning operations, goto, etc.
    The Run shows the resulting cut.
    Then I would like to run a 3d simulation.
    I select Execute | 3d Machine tool Simulation, and then use ST_Lathe.ppr
    DCAM replies "The Simulator data has been created."
    I click OK to run the simulation, but instead, mwSimulator replies
    "Error decoding tool select command line.
    TURN/TOOL/SELECT/1, TURNING TOOL
    System.InvalidCastException: Conversion from string "" to type 'Integer' is not valid...
    and a whole bunch of Microsoft VisualBasic exception information.
    How to get a simple simulation to run?
    This doesn't happen when running a milling simulation.
    Feb 2007
    417
    Re: Turning simulation throws exception
    Hello,
    Can you send the .cnc file you are suing to [email protected]
    ATB
    Andre
    Jul 2009
    56
    Files were sent. Have you any idea why the 3d lathe simulation fails, while the mill simulation example works fine?
    Feb 2007
    417
    Hello
    Sorry for the mess up, can you send the file to me please, Michael is away from the office at the moment.
    [email protected]
    ATB
    Andre
    Jul 2009
    56
    Files forwarded to you. Please take a look.
    Thanks.
  1. tool changer throws tools
    By steve pies in forum Haas Mills
    Last Post: 04-20-2015, 05:54 PM
  2. HELP, mach throws up random ESTOP mid program. Gecko G540
    By dougie329 in forum Mach Software (ArtSoft software)
    Last Post: 12-04-2011, 07:35 PM
  3. Alarme 1151 MCS Exception processing #13
    By dr_alexy in forum Okuma
    Last Post: 02-08-2011, 11:51 PM
  4. Mach 3 throws reset
    By dlaery in forum Taig Mills / Lathes
    Last Post: 07-22-2010, 04:39 PM
  5. MCS exception processing alarm
    By scorchtool in forum Okuma
    Last Post: 09-22-2008, 11:19 PM
