588,201 active members*
4,562 visitors online*
Results 1 to 5 of 5
    Jun 2009
    3
    TURRET PROBLEMS
    Hi. I have a "Mazak super quick turn 250 ms" yaer 1998. When i rotate the turret manually with the fwd/ccw button the turret works fine and tool positions is correct at display. But if i trying to change tool in mdi mode the turret start rotating with high speed and stops att wrong number. it sounds like it doesent clamp. i need to reset... then it clamp. I get alarm 272 and 221
    Apr 2008
    44
    you need to turret home setting, please see turret home procedure in operation manual book
    thanks
    Jan 2009
    17
    we are having basically the same issue. jogging the turret results in a high speed spin. we are thinking the encoder is bad.
    any other advice?
    oh, its alarm 221, too.
    Jul 2007
    284
    Just like Mazman said, you need to rehome the turret. If you cannot find the procedure in your manual it is best to call Mazak for it. It is usually easy enough to follow through with the procedure.
    Jun 2009
    3
    rehome the turret
    I called mazak and asked how i rehome the turret when i get the alarm with the turret clamp sensor. They told me that i dont need to home rehome the turret??? Can anyone explain to me how to do it.
  1. hass tool turret alignment problems!
    By Doug D in forum Haas Lathes
    Last Post: 03-27-2012, 04:26 PM
  2. Hardgine CHNC II turret problems
    By CatesMetal in forum Bridgeport / Hardinge Mills
    Last Post: 08-29-2009, 01:14 AM
  3. Star VNC 20 turret problems
    By tech5028 in forum CNC Swiss Screw Machines
    Last Post: 06-16-2008, 04:07 PM
  4. TL-1 Turret problems
    By RDemets in forum Haas Mills
    Last Post: 04-28-2008, 08:46 PM
  5. Turret alignment problems
    By coquina in forum Haas Mills
    Last Post: 07-18-2007, 12:53 AM
