587,610 active members*
3,360 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Upgrade of Huanyang vfd
Page 18 of 19 816171819
Results 341 to 360 of 378
  1. #341
    ericks Guest
    Re: Upgrade of Huanyang vfd
    Quote Originally Posted by potts43 View Post
    That sounds like a nightmare situation. They're lucky having someone with your experience that's able to troubleshoot to that depth!
    I've owned it for about 6 months. Cut quite a few bits so hopefully it will go well. These latest issues came from my Chinese vfd erroring on boot up. I replaced it with this one....it was supposed to have been set-up before it was dispatched to me.....you know the rest. Jokers!
    Sent from my SM-G935F using Tapatalk
    I was lazy....tired of being called to the machines all the time. Anyway it paid off, i now have a good design that i am able to use with any future project. Those Chinese drives don't seem to be very good....guess you get what you pay for. They just want to make a sale!
  2. #342
    ericks Guest
    Delta Electronics are also Chinese but they make reasonable stuff. I am buying a Delta EL series 1.5Kw drive for my new machine. Pity i didn't rather plan for a VLT like yours....it is good value for money and i am sure they are better than Delta drives.
    What size is your Drive and spindle motor?
  3. #343
    Jun 2017
    238
    Quote Originally Posted by ericks View Post
    2.2kw water cooled.
  4. #344
    ericks Guest
    2.2kw water cooled.
    Very nice!
  5. #345
    Jun 2017
    238
    Very nice!
    Cut out part 1 my project. I made the mistake of using too small a bit so took hours....but new vfd never skipped a beat. I feel I need to seriously speed up the cutting but not sure of the recommended way to know my machines limits.
    I'll cut the profile cuts on Monday and post the results. Work stops play 🤣
  6. #346
    Jun 2017
    238
    Ordered some 4 core CY cable. 10m should be enough to do the limit switches too.
  7. #347
    Jan 2005
    15362
    I'll cut the profile cuts on Monday and post the results. Work stops play ��
    Sometimes it is worth the extra money spent for quality parts, even if it is just for peace of mind, but it does not always mean they will last any longer
    Mactec54
  8. #348
    ericks Guest
    I'll cut the profile cuts on Monday and post the results. Work stops play 藍
    Thanks....i would love to see it
  9. #349
    Jun 2017
    238
    Did you get my PM?
    Fixed these to the kids loo....
  10. #350
    Jun 2017
    238
    Ericks I thought I would setup a z axis probe. I thought it would be a case of connecting it to the the two terminals on the left of the Bob. However whilst waiting for the probe to arrive I came across an article using our Bob but the wiring seems more complicated.
    Any thoughts?
    Thanks Jase
  11. #351
    ericks Guest
    Did you get my PM?
    Hi....yes i did receive your pm and replied
  12. #352
    ericks Guest
    I don't agree with that wiring.....your inputs get 12V from the 12V you supplied (12-24V) input. So don't mix your inputs with any other voltage in or output
  13. #353
    Jun 2017
    238
    So just wire the probe to the terminals on the left and forget the bottom 5v one's?
  14. #354
    Jun 2017
    238
    I thought it was using the 12v too and then use these terminals.
  15. #355
    ericks Guest
    Let me think....meantime don't connect anything to the 5V.....when you trigger a 12V input it "switches" 5V to your parallel port to mach3....no need to supply 5v....you will just short something out
  16. #356
    ericks Guest
    Let me explain.....the 12V is used to trigger/switch the optocoupler, then the output of the opto switches the 5V back to the pc....understand?
  17. #357
    Jun 2017
    238
    Not 100%....so which wiring plan is correct?
  18. #358
    Jun 2017
    238
    This was the info....
    Mach3 Zero Probe Tool
  19. #359
    Jun 2017
    238
    This is what I've ordered and probably follow. I like the idea of including the led too.
    https://youtu.be/tvV2Vmrxarc
  20. #360
    ericks Guest
    The one in the video doesn't require a specific voltage....it will work fine on your setup(inputs) Just wire it as a switch in one of your inputs and set it up according to the input you chose
  1. Huanyang VFD
    By lt00273 in forum Chinese Machines
    Last Post: 09-13-2017, 04:55 AM
  2. Huanyang VFD
    By lt00273 in forum Spindles / VFD
    Last Post: 09-07-2017, 06:10 PM
  3. Huanyang 2.2kW VFD.
    By atc40 in forum DIY CNC Router Table Machines
    Last Post: 10-19-2014, 04:33 PM
  4. Huanyang VFD
    By dwschool in forum Mach Lathe
    Last Post: 02-06-2013, 05:40 PM
  5. Huanyang VFD
    By moonman5 in forum Phase Converters
    Last Post: 01-19-2013, 05:43 AM
