603,946 active members*
2,270 visitors online*
Results 1 to 8 of 8
    Using mach for cnc robot
    Has anyone used mach to run a robot. What I'm trying to do is retro fit a Yamaha 3 axis robot, which shouldn't be that hard, but I also want the robot to cycle automatically using a sensor to start the cycle.
    Feb 2005
    487
    you can,
    There is a Plug in called "JogLearn" from the plugins download page, all you would do is use a MPG to position the arm and do its thing, and the plugin records the motion.
    you then save it, and the motion and routine saves as a Gcode file, that you can Run and the robot will repeat the motion everytime you run the G code.
    scott
    Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/
    thanks for the reply, but what I'm looking for is a way to interface a sensor to automatically run the program. This robot would be used in a production environment and would need to run without assistance.
    Jun 2004
    6618
    I am not really certain how to implement it, but I would think Mach could do it with a simple macro.
    Lee
    Jul 2005
    409
    clembrant,
    What type of sensor would you use to start the cycle?
    It may be possible to connect the "sensor" to the cycle start input of Mach.
    Cutmore
    I'm going to use a proximity or light sensor
    Feb 2005
    487
    oh, ok
    Then do this, bring in your sensor to, lets say INPUT4 in mach3, in Brains, map INPUT4, through a No-op lobe then terminate it with the "Cycle Start" button.
    For safty if you want you could also interlock the cycle start with a LED that when that LED is ON, then it would disable the cycle start.
    You could also do it in the Macropump using VB, or a Plugin.
    scott
    Thanks for the good info. I don't have the robot yet, but should be getting it soon. I have a lot more questions, but I'll wait until I get the unit
  1. Mach 3 robot?
    By pointcloud in forum Mach Mill
    Last Post: 11-08-2012, 06:55 AM
  2. Looking for Robot Auto Palletising (Panarobo and or STORK Robot)
    By rsarwanto in forum European Club House
    Last Post: 09-12-2008, 12:22 PM
  3. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
  4. CNC to Robot
    By GT_racing in forum G-Code Programing
    Last Post: 05-24-2006, 02:18 PM
  5. robot arm help
    By magicruss in forum RC Robotics and Autonomous Robots
    Last Post: 03-02-2005, 06:06 AM
