587,786 active members*
2,483 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V24, moving start point
Results 1 to 7 of 7
    Mar 2010
    54
    I have a simple contour that I am chamfering. I want to change the start point.
    I select Start Point in the Chamfer Cut Feature and I see the start point appear. One would think I could simply grab it and move it to where I want it. Apparently not. How do I move it?
    Tom
    May 2008
    244
    right click start point
    right click modify, arrow should appear and high light geometry
    start point will be at beginning, middle or end of a line
    left click line to move arrow
    if none of those places are where you need it to be
    then use break in utilities to break geo. where you need it to be
    Mar 2010
    54
    Quote Originally Posted by dwood View Post
    That worked, thanks! Seems they went out of their way to make the UI obtuse. Oh well, onward...
    Tom
    Mar 2010
    54
    Tom
    Mar 2010
    54
    Climb milling
    I have another issue with start point. If I select reverse direction on the start point it won't post in the reverse direction. It also won't verify.
    Also, if after I select reverse direction I then compute new tools paths, my tool path changes to an inside profile rather than an outside profile. To get it back, I have to reslect geometry and then recompute toolpaths. however, this then puts the start points back to their original direction.
    What is the step by step procedure for changing the direction of the start point (to climb mill) and then get it to take so it will Verify and also post?
    Tom
    Feb 2010
    You will also need to change the system compensation from left to right. You will find this under patterns when you run the wizard.
    Mar 2010
    54
    Quote Originally Posted by Jerry3672 View Post
    Thanks Jerry. Someone in the shop helped me figure out exactly that today. That turned out to be the root of several problems I was seeing. Once we changed the compensation, the start point worked as well as my toolpaths stopped moving to the other side which I thought was a bug.
    That raises another question which perhaps you know the answer to. What is the difference between machine compensation and system compensation and when would I use one over the other and would I ever use both?
    Tom
  1. line out start point
    By kendo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-26-2010, 01:00 AM
  2. Cutting start point
    By Mago in forum SheetCam
    Last Post: 05-28-2009, 02:52 PM
  3. Use a point for the start point of a profile.
    By dcskid in forum BobCad-Cam
    Last Post: 03-18-2009, 04:31 PM
  4. re start point
    By woffler in forum BobCad-Cam
    Last Post: 11-06-2008, 02:56 AM
  5. Where to start ? point me in the right direction...
    By cruizer67 in forum DIY CNC Router Table Machines
    Last Post: 09-13-2005, 02:44 AM
