I'm not really acquainted with what wye and delta switching does in 3 phase motors.
What is considered 'standard configuration'?
Does it have to do with number of 'poles' of the motor being doubled or halved?
I've gleaned over time that a 4 pole motor is probably standard for 1725rpm motors, and has the maximum torque available, and that you'll never get 'more torque' than a standard motor by wye/delta switching, but you might enjoy more speed and less torque.
So if you are used to a gearbox machine and have applications that need the increase in torque, then a dual drive without a gearbox is not likely a valid substitution.
I might be wrong, so school me if you know better
First you get good, then you get fast. Then grouchiness sets in.
