603,311 active members*
2,031 visitors online*
IndustryArena Forum: Vertical Mill, Lathe Project Log
Page 13 of 38 3111213141523
Threads 241 to 260 of 760
Post your project building or converting logs here for lathes or milling machines.
  1. Lightbulb Sticky Thread Sticky: 18x18 Linear Rail Tormach Build.
    Started by nateman_doo, 05-23-2012 07:42 PM
    51 Pages
    1 2 3 4 5 ... 51
    06-22-2025, 06:44 PM Go to last post
    12-10-2014, 09:38 AM Go to last post
  1. Hafco Metal Master HM-52 CNC Conversion
    Started by chich2, 10-16-2006 01:15 PM
    17 Pages
    1 2 3 4 5 ... 17
    11-28-2014, 12:47 PM Go to last post
  2. Please help identify this Milling Machine
    Started by kimy_cool, 10-31-2014 05:58 PM
    10-31-2014, 08:30 PM Go to last post
  3. Spindle for DIY mill build
    Started by Jkurtis, 10-23-2014 03:05 AM
    10-29-2014, 12:43 AM Go to last post
  4. Alan's DIY CNC Mill
    Started by alan_3301, 10-18-2014 05:12 PM
    10-18-2014, 10:30 PM Go to last post
  5. CNC Lathe made by Monkey King
    Started by Monkey King, 02-06-2010 03:04 PM
    5 Pages
    1 2 3 4 5
    10-04-2014, 08:57 PM Go to last post
  6. steel tube bridge mill
    Started by lgcnc, 09-21-2014 06:17 PM
    09-23-2014, 03:16 PM Go to last post
  7. Ball screw choice
    Started by laserpilot, 09-20-2014 01:32 AM
    ..., 25 mm, aluminium, axis, ball, ball screw, build, design, dia, drives, large, long, machine, milling, milling machine, nema, nut, pitch, plate, screw, size, star
    09-22-2014, 03:24 AM Go to last post
  8. Spindle Choice
    Started by laserpilot, 09-20-2014 11:40 PM
    20mm, axis, ballscrew, bearings, cnc, collet, costs, cut, cutting, deep, design, drill holes, gantry, holder, job, linear, machine, motor, rails, shaft, spindle, steel
    09-22-2014, 01:22 AM Go to last post
  9. Talking E/G CNC Mill
    Started by thewho, 06-08-2011 09:52 PM
    4 Pages
    1 2 3 4
    09-04-2014, 05:09 PM Go to last post
    08-26-2014, 08:36 AM Go to last post
    08-25-2014, 03:54 PM Go to last post
  10. What retrofit candidate for my constraints?
    Started by brennon272, 08-18-2014 05:43 AM
    aluminum, angle, bridgeport, cam, cnc, control, fast, grizzly, machines, mill, power supply, product, project, retrofit, solidworks, speed, steel, supply, tormach, versus
    08-20-2014, 04:19 AM Go to last post
  11. My KX3, tweaks and various stuff
    Started by Guldberg, 03-26-2009 10:13 AM
    4 Pages
    1 2 3 4
    08-09-2014, 03:25 PM Go to last post
  12. D&M 3 CNC Lathe
    Started by lorneboy, 05-02-2012 12:25 AM
    08-08-2014, 02:45 AM Go to last post
  13. G0602 conversion
    Started by Transformer1626, 08-06-2014 05:02 AM
    602, anyone, apparently, appreciated, bdtools, can, conversion, ebay, find, g0602, grizzly, hat, kit, know, lathe, leads, offer, tha, thanks, used, version
    08-07-2014, 04:13 AM Go to last post
  14. Defeng is on the mend
    Started by DagnWal, 03-28-2014 04:13 AM
    defeng, email, mend, orders, today
    07-27-2014, 09:13 AM Go to last post
  15. Brother TC-225 Rebuild & Retrofit
    Started by PIVOTALCUSTOMS, 12-20-2013 11:04 PM
    2 Pages
    1 2
    321, brother, drill tap, industry, longer, mach 3, master machinist, rebuild, retrofit, something, tc 225
    07-16-2014, 10:37 PM Go to last post
  16. Cast Iron CNC Mill Design
    Started by thegolfer, 05-14-2014 03:04 AM
    07-10-2014, 02:57 AM Go to last post
  17. My little homemade benchtop mini lathe
    Started by baskarz, 07-03-2014 01:21 PM
    07-05-2014, 03:49 AM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 4 users browsing this forum. (0 members & 4 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
