603,365 active members*
3,193 visitors online*
IndustryArena Forum: Vertical Mill, Lathe Project Log
Page 12 of 38 2101112131422
Threads 221 to 240 of 760
Post your project building or converting logs here for lathes or milling machines.
  1. Lightbulb Sticky Thread Sticky: 18x18 Linear Rail Tormach Build.
    Started by nateman_doo, 05-23-2012 07:42 PM
    51 Pages
    1 2 3 4 5 ... 51
    06-22-2025, 06:44 PM Go to last post
    05-25-2015, 02:20 AM Go to last post
  1. 6x12 weld steel hobbies build.
    Started by khoac3, 06-20-2014 01:36 PM
    3 Pages
    1 2 3
    032, 60e, everyone, its, lovely
    05-15-2015, 03:23 PM Go to last post
  2. Cool YOSHIDA YMC-60V Vertical Machining Centre Retrofit
    Started by chich2, 11-02-2014 11:54 AM
    2 Pages
    1 2
    05-06-2015, 10:22 AM Go to last post
  3. suga st-200
    Started by sargent, 05-03-2015 05:07 PM
    controls, lost, perimeters, st-200, suga
    05-03-2015, 05:07 PM Go to last post
  4. Opti BF20L CNC conversion
    Started by speed_racer, 04-21-2015 02:11 AM
    ballscrew, cnc, kit, nut, table
    04-28-2015, 01:23 PM Go to last post
  5. Alan's DIY CNC Lathe
    Started by alan_3301, 04-09-2014 11:42 AM
    2 Pages
    1 2
    04-23-2015, 12:57 AM Go to last post
  6. Smile Another Hardinge HNC Retrofit
    Started by DennisCNC, 01-06-2007 01:58 AM
    another, cabine, candle, doi, everyone, forum, hnc, lathe, not
    04-11-2015, 04:44 AM Go to last post
  7. Drill bits for CNC drilling
    Started by TTalma, 03-20-2015 04:32 PM
    brass, breaking, buy, cnc, drilling
    03-27-2015, 03:11 PM Go to last post
  8. CNC a PM Lathe?
    Started by slammedxonair, 03-01-2014 01:41 AM
    2 Pages
    1 2
    03-20-2015, 06:07 PM Go to last post
    03-04-2015, 09:13 AM Go to last post
  9. conect cnc lathe retrofit
    Started by daedalus, 08-26-2006 01:59 AM
    2 Pages
    1 2
    03-01-2015, 09:42 AM Go to last post
  10. CNC Lathe with Hiwin rails
    Started by whimsical, 02-23-2015 02:52 PM
    25mm, added, cnc, rails, tail
    02-24-2015, 08:39 AM Go to last post
  11. MISSING AC SPINDLE DRIVE + 3 AXIS SERVO DRIVE
    Started by Affaq999, 02-13-2015 06:35 PM
    axis, cnc, drive, missing, spindle
    02-20-2015, 03:50 AM Go to last post
  12. My Gingery Inspired lathe project
    Started by AxelFoley, 12-21-2014 08:07 AM
    3 Pages
    1 2 3
    02-08-2015, 03:27 AM Go to last post
  13. CNC Vertical Milling machine DIY
    Started by Jclinedinst, 01-29-2015 04:44 PM
    01-30-2015, 02:04 PM Go to last post
    01-06-2015, 06:24 PM Go to last post
    01-01-2015, 03:39 PM Go to last post
  14. Hafco 12x36 CNC conversion
    Started by proengines, 10-10-2014 12:16 PM
    2 Pages
    1 2
    bits, case, cleaning, cnc, cnc conversion, colchester, conversion, gearbox, hafco, headstock, hi all, lathe, leadscrews, local, master, member, mid, packing, proe, short, wax, work, workshop
    12-24-2014, 05:29 PM Go to last post
  15. Cast Aluminum and extruded Mill Build
    Started by Rotorworkz, 11-26-2014 04:58 AM
    12-20-2014, 08:21 PM Go to last post
  16. Looking for DIY 5 Axis builds
    Started by turbostang, 08-06-2008 06:21 PM
    12-16-2014, 10:02 AM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 6 users browsing this forum. (0 members & 6 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
