603,870 active members*
3,197 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Visual quick code parameters
Results 1 to 14 of 14
    Jan 2007
    1389
    Have a question, I dont use the visual quick code programm o9996 at all, I do use the program number o9997 like everyday. This is the program for the probe and tool setter.
    is there a parameter that I can change so when you pres MDI then scroll to the VQC tab and hit enter the 09997 comes up instead of having to press F2 then select o9997.
    I had thought my HFO told me its a setting but wasnt sure, so I figured I would ask here first.
    Delw
    Mar 2008
    638
    You could turn off setting 23 to show all the O9000 programs but there is a lot of them.
    How about creating a short program that just calls O9997 ?
    Like
    O8997 (CALL O9997)
    M98 P9997
    M30
    Mar 2008
    638
    Sorry. I wasn't paying attention. That's a VQC program where you are going to input variables? I'm not sure an external call will do it right. The VF-2ss is running right now so I can't check.
    Edit: Just checked. I'm totally off base.
    Nov 2003
    236
    Try parameter 228. You will need to turn setting 7 off and press e-stop to change the value. --- OOPS that is quick code and not VQC. Maybe you can try to change the program number.
    Jan 2007
    1389
    maybe I made it sound worse than it is by tossing the program numbers in it.( as thats what I see when I hit the "f2" key
    when you goto the vdc tab on the far right, you need to press "F2" so you can get the probe menu up. the default is the VQC program menu.
    Thats all I want to do is bypass the hitting "f2" every time.( or the default if you will from VQC program menu to VDQ Probe Menu) was hoping that I could just cursor right to the VQC tab and my probe program list be in there instead of the quick program list.
    I just assumed there would be a parameter to swap the probe menu and the program menu under that tab.
    I only have to hit "F2" everytime I power up so its not that big of a deal.
    sorry for any confusion. as I am sure I just made it worse
    Delw
    Nov 2003
    236
    Try swapping the program numbers in these two programs
    Jan 2007
    1389
    LOL I was thinking that when re reading some of the replies, Thanks
    I will try that in a few and see whats happens,
    Delw
    Nov 2003
    236
    Let me know if it works? If not I will keep on trying to think of other ways.
    Nov 2007
    1704
    Wayne,
    What would happen if you combined the two files into one larger file? Would you get both the normal VQC templates and the probing templates in one larger series of templates? Or would that overwhelm the menu system under VQC? I'm still not well versed on how all those templates are created and displayed on the screen.
    Greg
    Jan 2007
    1389
    Thats a good qestion Donkey
    BTW I couldnt find the program name, is it protected or do I have to look under macros?
    Delw
    Nov 2007
    1704
    Combining VQC templates
    Just a follow-up of the question I posted above: could you combine VQC templates to make one, 'super menu' with all of the VQC options listed at once?
    The answer is: yes, it works just fine. I have been training a coworker on how to use the new machines at work. He had enough to try to swallow without having to contend with, "What eleven keys do I have to press to get to the probing commands?"
    I moved 00996 and O0997 to my PC and backed them up in a different folder.
    I opened both files, copied the entirety of the O0996 file (except the program name and the ending M30). I pasted that into O0997, in the block right after the program number, then saved it to the thumbdrive. I moved that file back to the machine and reloaded it. Now when I call up the VQC temlates, it lists all of the probing menus first, then the standard VQC menus right after them. Sweet!
    Greg
    Jan 2007
    1389
    no kidding thats cool.
    see if I got this right.
    grab everything out of the o0996 file EXCEPT the program name and the ending M30 paste it into the o0997 program?
    Since I am here working on my fadal I will fire up the haas and try it right now.
    thanks
    Delw
    Jan 2007
    1389
    Donkey/Haas App.
    today I has some warrenty work done and was screwing with the machine. we just changed the 2 program numbers and it worked fine. didnt have to alter the program at all.
    now when the machine powers on and you go into quick code you don't have to hit F2 to call up the probing and tool setting routines.
    I am only 8 months late in doing it LOL
    Jan 2011
    Can somebody send me a copy of O0997. I bought a VF-2 and it didnt come with the VQC software. I need a copy of the program so I can load it in to get VQC. I would greatly appreciate it.
    Jason
  1. Haas Visual Quick Code (VQC)
    By ethal68 in forum Haas Visual Quick Code
    Last Post: 02-10-2014, 04:51 AM
  2. haas quick code for pc
    By old machinist in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-24-2009, 03:23 AM
  3. Visual Quick Code on TL4
    By speeeeed in forum Haas Lathes
    Last Post: 01-14-2008, 09:49 PM
  4. Quick Code, Visual Quick Code
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-17-2006, 04:46 PM
  5. Haas visual quick code
    By GENMACH in forum Haas Visual Quick Code
    Last Post: 11-16-2005, 08:07 PM
