587,997 active members*
1,689 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > VMC 4020 to RS232 /serial/ cable
Page 1 of 2 12
Results 1 to 20 of 26
    Jul 2011
    105
    Exclamation VMC 4020 to RS232 /serial/ cable
    Hi !
    Ive a VMC4020 /ht/ in workshop. Tried to connect to PC.
    Acually it is a laptop with USB-RS232 converter. it have worked fine with cisco devices. router , switch etc.
    So i did connected it to fadal but it didnt worked. I guess some pins are not at the desired place. There is only 5 wires connected to the DB25 outlet.
    RED , BLUE , BROWN , GREEN , YELLOW
    Yellow is Ground thats for sure.
    RED is connected to PIN 3
    BLUE pin 4
    BROWN pin 2
    GREEN pin 20
    Yellow pin 7
    According to User manual ....Pin1-shielded, pin2-TX, pin3-RX, pin4-RTS, pin7-GND, pin20-DTR
    Is this correct ?
    AKOS
    Jul 2011
    105
    Question step 1
    HI !
    Ive made some progress. 1st the cabel was OK but the 9to25 converter mades a cross connection so the TX went to TX so it did not worked at all. Ive soldered the fadals cable to work OK. :cheers:
    But there is a problem again. If i connect the serial cable to fadal it goes "nervous" the sound of the servo cards changes and the servos are jumping sometimes a bit. When sending data or fadal is sending to PC the sound goes normal again. but in IDLE connection the CNC is wispering...
    It is a shielding , or grounding problem ? Or whats going on ?
    AKOS
    Nov 2007
    78
    Hi!
    I had a similar problem. Once you plug the cabel from PC to the 4020
    the keyboard on the Fadal not responding properly.
    I think there are irridations on the RS232 from the Fadal so the machine
    "listen" to the interface. I've use several cabels - nothing happens.
    The I use a bluetooth-connection with two little converters (RS232-Bluetooth).
    Now it seems all is fine.
    Bye
    Thomas
    Mar 2010
    fadals do need a null modem.
    Jul 2011
    JQ Laser
    Hello
    I have not received your reply. have you got my email? and my youtobe is jqlaser33, please have a visit
    Casper Geng
    Quote Originally Posted by pilot001 View Post
    Hi !
    BLUE pin 4
    BROWN pin 2
    GREEN pin 20
    Yellow pin 7
    Is this correct ?
    AKOS
    Jul 2011
    105
    Lightbulb thomas
    Hello Thomas !
    can you describe the serial connection with the bluetooth module ?
    I have a bluetooth panel with a serial conn on it. On the PC side it is good to have a simple BT dongle /like a pen drive but smaller/. ? Or some special stuff is needed ?
    AKOS
    FADAL VMC4020 HT 1995, Z 28" (if true) , 88HS , 10K rmp , 21 TC geneva /rotary/ , VH-65 (A-axis) ,3ph 400V , metric, NO conveyor, No palette. (+alternative DC AMP)
    Nov 2007
    78
    Hi!
    I use two "BT-BluSer1" from BlueSerial Bluetooth Products for RS232 Cable Replacement, high range for Industrial Automation, Medical, Automotive.
    It works fine, so the PC has a serial-interface over bluetooth and
    the fadal-dnc-software works fine.
    Bye,
    Thomas
    Jul 2011
    105
    So a normal BT usb device will be ok for it ? Some kind a virtual PRG is needed to emulate a COM port on pc ?
    DO you use MSN or Skype ? Or something else ?
    AKOS
    Nov 2007
    78
    i use two converters rs232 to bt
    so pc use the real com-port, and fadal too, of course
    Jul 2011
    105
    gg
    Hi !
    Can it be used with USB BT ? probably it will need a virtual com stuff...
    NO MSN ? NO skype ?
    AKOS
    Nov 2007
    78
    if the dnc-software support the virtual com-port: why not.
    sorry - no msn....
    please use this forum
    Jul 2011
    105
    conn
    Hi !
    In the first place i'd like to use it to upload PRGs to CNC from PC.
    I can not send you PMs code probably you disabled it.
    AKOS
    Nov 2007
    78
    try a adaptor usb->rs232 and use nc-fadal
    i don't know how it works
    Jul 2011
    105
    db
    HI ...
    So you plugged a device to PC's serial port /DB9/ and one device to fadals db25 or db9 port ?
    I got this "system" : PC has a USB BT "dongle" Fadal has a BT to Serial converter.
    I got some data flow dut it aint right somhow. Sometime i get parity error , sometimes manly crap. crap is random letters , signs etc... so no real data for fadal... what can be wrong here ?
    AKOS
    Nov 2007
    78
    Hi!
    What software do you use? I have tested it too and with nc-fadal
    i cant send programms. seems the virutal com-port on pc is not
    "good" for nc-fadal.
    second i use a "dongel" on pc too (use n,8,1 - its "the same" as e,7,1)
    and it runs fine. the pc use a serial port or a usb-serial adapter.
    bye
    thomas
    Jul 2011
    105
    com
    Hi !
    SO you say that if i use the PC with USB connected BT it wont work ?
    I must use the real COM1 at pc with a BT ? at fadal BT to com is OK ?
    Connect-cnc software i have. its working with wired connection to fadal. RX ,TX , GND.
    your EMAIL : [email protected] ? ?
    AKOS
  17. #17
    Nov 2007
    78
    have you ever test once?
    don't look so.
  18. #18
    Jul 2011
    105
    HI
    Test ? what kind a test ?
  19. #19
    Nov 2007
    78
    okay - i see, we come to no right way.
    another idea:
    there is an option for fadal you can use a simple usb-stick and plug it
    directly to the fadal. then you can load the programm from the stick.
    please conact your local fadal-dealer for details.
  20. #20
    Jul 2011
    105
    HI !
    Actually the normal serial cable is working but maybe i can use BT for it too. ill try to use this com-bt --- bt-com configuration.
    Akos
Page 1 of 2 12
  1. Serial Cable
    By TurboVR4 in forum DNC Problems and Solutions
    Last Post: 06-05-2009, 12:49 AM
  2. Pin out of the serial cable??!
    By hodge98ws6 in forum Syil Products
    Last Post: 05-07-2008, 10:03 AM
  3. cat 5 cable for serial?
    By krfrea in forum DNC Problems and Solutions
    Last Post: 12-12-2007, 04:49 AM
  4. Serial cable help
    By turbo_todd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-12-2005, 03:52 PM
  5. rs232\serial port (Voltage)
    By j m in forum Computers / Desktops / Networking
    Last Post: 08-05-2005, 01:43 PM
