587,655 active members*
4,102 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Want to control your spindle with Mach3 but can't.. Maybe this helps.
Page 7 of 23 5678917
Results 121 to 140 of 443
  1. #121
    Dec 2007
    72
    Just subscribing
  2. #122
    Oct 2008
    1641
    Oops, I was in a hurry and that came out a little crappy. I meant to say, I work with pics everyday at my job so I have all the tools. That happened to be one of the first things I checked and they were protected.
    Sorry about that,
    Richard
    Quote Originally Posted by rwskinner View Post
    I do pic micros for a living. The chip is protected, write but no read.
    Richard
  3. #123
    Feb 2009
    137
    Good that you have experience. Why would you change it out for an ATMEGA?
  4. #124
    Oct 2008
    1641
    I wouldn't. I said once I got my mill going, I was going to start attacking the "original" board.
    I only played with the Atmel's back in 2004-5 or so when they came out with their STK for $50. Nice promotion they had and seemed like nice chips, but All my main tools were already for the pic micros and it still remains that way.
  5. #125
    Oct 2008
    1641
    I had to cut a 1.500 ID Pocket in Cast Iron today.
    I used a 1/2" end mill, 575 spindle rpm, feed rate way slow 2 ipm and a plunge of 1 ipm. DOC 0.025 per pass.
    The motor stalled on 2 out of 3 plunges. My stock motor never did this.
    I wonder if Keling gives refunds?
    Richard
  6. #126
    Oct 2008
    1641
    BTW, I forgot to update this thread. John at KelingInc made everything right by me and was more than fair. John always seems to come thru.
  7. #127
    Aug 2007
    162
    So you returned it and got a refund?
  8. #128
    Oct 2008
    1641
    Yes.
  9. #129
    May 2007
    715
    Keling is certainly not the issue here, If Sangmutan can fix the issue and get new parts out to us, then the problem will be resolved.
  10. #130
    Oct 2010
    25
    Has the issue with these defective Sangmutan motor controllers been resolved yet?
  11. #131
    Dec 2010
    55
    Not yet it seems:
    http://www.cnczone.com/forums/produc...ldc_motor.html
    Given the time its taken to try and do a "quick fix", a complete re-design means we probably wont get anything till the year end...
  12. #132
    May 2007
    250
    How to connect BLDC driver and C11g BOB ?
    Chris,
    I have 2200 W,6000 RPM BLDC motor and the driver from Sangmutan.
    I have C11g BOB also.
    I try to connect the BLDC driver of Sangmutan to C11G BOB but it's not successful. Do you have the wiring diagram to connect them ?
    Mongkol
  13. #133
    May 2007
    250
    Chris,
    I see the two blue-wires going to CN5 on the driver.Where are they come from ?
    I guess they come from C11G BOB but I don't know how to connect. Pls advise
    Mongkol
  14. #134
    May 2007
    250
    Smile
    Sorry, The number is wrong. again.
    I see the two blue-wires going to CN7 on the driver.Where are they come from ?
    Mongkol
  15. #135
    Oct 2005
    1237
    Has anyone tried using a different drive with this motor? There are many brushless Advanced Motion Control drives on eBay. Some seem down right cheap compared to the failed drives.
  16. #136
    Sep 2007
    200
    sorry to ask. but how many of you have ruled out a timing misalignment?
    the sangmutan is a sensored motor, does retarding the timing have any improvement?
  17. #137
    Sep 2007
    200
    i would just hate to see the producer of these motors seem stupid because the timing wasn't set properly.
  18. #138
    Oct 2010
    25
    Quote Originally Posted by draughted View Post
    'sensored'. Is this a new word?.
    'Censored' is what this excuse for a motor control system should be.
    These motors have revolution feedback only, there is no way they have any timing sense.
    However please ask Sangmutan/Zhang this question and post the response.
  19. #139
    Sep 2007
    200
    oh!
  20. #140
    Oct 2010
    Just lucky!!!
    I have 2 of the samutang 2200 watt motors and found them to be excellent performers until I Upgraded my machine to the newer versions of Mach3 and a smoothe stepper. then I had weeks of frustration trying to get the darn things to get near target spindle RPM, They also seemed to be developing less power.
    This last weekend I downloaded Machstdmill screen sets. and it seems that my problems have been greatly improved. My spindle now runs dead on RPM and some of the other quirks and bugs have smoothed out. it seems the torque has improved also, Spool up time is still a little slow about 5 seconds to hit 2000 but better than 8 or 9.
    I don't know if it is coincedental but I am happy!!
  1. Getting C11/Mach3 to control 2.2kw Spindle
    By kostas1 in forum Mach Software (ArtSoft software)
    Last Post: 12-10-2013, 03:53 PM
  2. helps with overheating of spindle motor..
    By victorcnc in forum Servo Motors / Drives
    Last Post: 03-08-2011, 06:55 AM
  3. MEI LC/DSP Prof. Motion Control. Wo helps me on: Software and drivers?
    By Harmpy35 in forum CNC Machine Related Electronics
    Last Post: 08-07-2010, 09:59 PM
  4. mach3 spindle control on nm-200
    By urbanimports02 in forum Novakon
    Last Post: 01-19-2010, 04:33 PM
  5. VSD-A Spindle control in MACH3?
    By mkuivamaki in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-08-2008, 08:09 PM
