588,563 active members*
4,975 visitors online*
Results 1 to 18 of 18
    May 2003
    267
    Welding advice
    I am new to MIG welding and tried it a couple of times using mild steel tubing (1/8" thick) on some projects. I have noticed that as the welds cool, the mild steel begins to warp. I heard that tack welding (welding small area) should be done to secure the two pieces in position before putting a bead of weld over the entire weld area. What is the technique or secret I should be using? Should I wait to allow the tacks to cool (for how many minutes) before welding long beads? Should I avoid welding long beads? Should I be looking at the spark and making sure it hits the exact area I want to weld?
    Any advice for a beginner is appreciated. I would like to get near expert welding results if possible.
    May 2003
    109
    For metal that thin you can't do 'long beads' , Stagger and do 1/2 - 1" beads.
    Also what amperage are you running? (If your machine has a four position switch, take the machine amperage and divide by 4 to tell you what each postions amperage is)
    Jun 2003
    1365
    yah, he is right, and tacking is a technique, you want to tack both ends together at least, and even the middle in a few places if you need.
    I know I have layed long beads on stuff like that but most of the time it tends to warp.
    Jon
    Mar 2003
    4826
    George,
    You're new to MIG but want near expert results? Don't we all?
    Anyways, you are going to get some warping. But, the voltage and wirespeed are very closely tied together, so you have to play with the settings a bit to figure out the lowest heat setting that you can use to still get a good bond.
    At low settings, the weld metal is going to transfer in globules, at quite high settings, spray transfer may begin to occur. Spray transfer creates a beautiful weld, but dumps lots of heat into it, too
    Globular transfer does not sound nearly as nice, its kind of like water spitting in a hot skillet. However, this is most likely the mode you will be in, due to using lower wirespeed and voltage settings. Proper settings will result in a rapid-fire crackling sound.
    Inert gas flux is required for a lower spatter and better looking weld, as well. There are three, or so, mixes of inert gas (that I am familiar with) used for steel welding. These all have an effect on the "heat" of the process. Talk to your gas supplier about the best choice for what you want, which is low heat, thin material welding.
    The proper wire speed setting will keep the melt zone a 1/4 inch or so away from the copper tip of the MIG gun. This melt zone distance should increase as you increase the voltage, to prevent overheating the tip and the subsequent sticking of the wire inside of it.
    For an .035 wire size, using what we call "MIG Mix Gold" inert gas, you can begin at 15volts about 160 inches per minute wire speed. If you use smaller wire, you can decrease these settings further.
    First you get good, then you get fast. Then grouchiness sets in.
    Apr 2004
    678
    Try this once:
    Take a 10mm steel rod and make it a bit pointed. Tack it to a thick steel plate. Ask someone to grab it at the top, not too close of course. Then at full amperage quickly run a bead around it. I'm sure you'll get a surprised face as a reward. I did this and the guy started laughing. The rod wagged like a dog's tail.
    Try to lay the two pieces close at the end you start welding, and with some space between them at the other end. When you get this right, they will meet each other as you get to the other end. Then they will contain less strain than if you tack them. When you tack them they will not be allowed to contract and that leaves you with more strain in the finished material. And if you have to grind off a lot of bead after you're finished, you have put in too much metal and thus heat, try with less the next time.
    Go buy this book: "Modern Welding" Althouse, Turnquist, Bowditch, Bowditch. ISBN 0-87006-668-4.
    It's not cheap, but the best coverage I've seen on welding. Also covers soldering and brazing.
    Mar 2004
    564
    For more proffesional looking welds, also prepare the metal joints first by beveling the edges that you intend on joining. Clamp everything, and leave it clamped until things are cool enough to handle.Proper grounding is critical to smooth flow of current aswell, make sure there are no rust or painted surfaces you are trying to cross. If you are welding outside (or with a fan blowing on/near you) try to weld elsewhere, or block the wind, The sheilding gases used easily blow away and affect the welding process, and can contribute to welds that fail later in life. If you are getting splatter and feel you have the right settings you can buy anti-spatter (goop) that you dunk the tip of the mig gun in. If you don't have a gas set-up for your mig, use Flux cored wire, and you will get similar results to using gas.
    As an industrial machine builder, I try to stick to the above rules, I have been welding close to 10 years and I still have days where I have to shake my head after welding.
    bcromwell and huflungdung have good advice also that should be practiced to get nice welds.....
    good luck
    menomana
    Apr 2004
    96
    All of the above is sound advice. To that I will add the need for practice. Close fitting joints help minimize the pull. It is not uncommon to tack the entire assembly before any welds are completed.
    You will get significantly better welds with MIG (metal inert gas) if your metal is absolutely clean and free of mill scale. Flux core wire is more tolerant to surface contamination. You did not say which process you are using.
    Mar 2003
    214
    To minimize warpage and pull, tack both ends, then use a method called backstepping. Lets say you are making a 12 inch long weld. Start your first weld 3 inches from where you would normally end the long weld. When you've welded that 3 inches, go three inches in front of the start of the 1st weld and weld to the start of the 1st weld and so on. Tacking also helps.
    May 2003
    267
    I am using gasless mig welding. My mig is a 220V mig and is rated as being able to weld 1/4" thick metals (I am assuming 1/4" is the thickness of one of the pieces and not the thickness of both pieces combined). My question is can I weld mild steel that is upto 3/8" thick? Also, will tack welding (w/o using beads of welds or intermittent welds) be good and strong enough for mild steel w/o putting welding beads?
    Mar 2003
    4826
    George,
    how many amps is your machine rated at? What diameter wire is it rated to handle?
    With multipass welding it is of course, possible to weld greater thicknesses. However, that being said, you should weld at a higher heat setting (higher voltage and wirespeed) when welding thicker materials to avoid cold lap and brittle joints. A bit of base metal preheat can help avoid brittle weld joints, too.
    One simple test to determine if your heat setting is right, is to weld a couple of sample pieces of mild steel ("iron") together on one side only (a simple butt weld). Then, clamp the piece in a vice right near the weld zone. Hit it with a hammer. If it immediately breaks out beside the weld, then the base metal was too cold. This can be remedied by either preheating, or welding at a higher heat.
    Of course, you will always succeed at breaking the piece off eventually when doing this test, but by observing the amount of stretching in the weld zone as the piece bends over, this gives you an idea of the ductility of the weld joint. For mild steels, you would expect the joint to stand some bending, as opposed to just snapping off immediately.
    Nov 2003
    299
    Good way to test a weld Hu, U never cease to amaze me with your knowledge of this stuff.
    George, when your welding you want to move the wire from one piece to the other in a cicular pattern. Make little circles from one piece to the other. Go slowly so the heat has enough time to penatrate and make a pool of molten metal.
    Try this to get a really nice weld, set your pieces up so you can weld straight up and down. Start from the top and draw your bead down the piece. Let gravity keep the bead flowing and work your torch in a zig-zag pattern like I said. Practice, Practice, Practice...
    May 2003
    267
    HuFlungDung,
    I have a Clarke 220V 180Amp MIG uisng 0.35 wire size with gasless flux core wire.
    InventIt,
    What do you mean by circular pattern, moving from one piece to the other, in a zig zag pattern? Are you saying to create small circular patterns (say about 3/8" dia. circles) starting on one piece (in a 2 piece joint) and slowly moving to the second piece (using circular motions all the time)? That sounds very similar to when I took a Acetylen/Oxygen welding class back in 1985 in high school. Any similarities with the 2 techniques (MIG vs. ACEY/OXY)? Any more advice? I plan to weld something on Saturday.
    Thanks,
    Mar 2003
    214
    I found a long time ago that the key to good welding is being able to look into the weld puddle and see that you are melting both sides of the joint. Also under carefull scrutinization you can see when you have complete penetration. It takes alot of practice and comparing, but you can see it all, and you can also see the impurities float to the top. Once you can recognize the fusing of the two you are well on your way. I'll never forget when I was growing up on our farm. A gear fell off our hay bailer because even though there was a beautiful bead of weld, it had failed to fuse to one side.
    Ken
    Jan 2004
    490
    One of the biggest mistakes that most people make with different welding techniques, is that they treat them to different. The most basic, and often overlooked part of welding, is to work the puddle. I gas, TIG, MIG, and stick weld, and do it for a living, and I do almost everything with the same two techniques. Either I weave back and forth accross the joint, or I use curcular patterns. MIG welding can be very much like gas welding in certain instances. With thicker materials, and smaller gaps, circular oxy/acet type of motion works very well. It almost has the effect of preheating the metal before you actually weld it. In this instance, you would overlap about 1/4 to 1/2 of the previous circle, and as you move forward, there is a small space between the outer line of the new pattern, and the part that will be overlapped. I think I am not making any sense. Try this...draw a row of circles on a piece of paper. half lap each circle in succession. Looking at these circular outlines as you weld bead, you can see that although there are spaces between the centers, they all end up overlapping. That is the same thing that happens with weld. All the advice above is very valid, and the most important part as previously stated is to practice. Pay attention to your puddle, and work it!
    Stop talking about it and do it already!!!!!
    May 2003
    267
    What is the diferrence between flux-core and innershield for gasless MIG welding? It seems that the flux-core welds better for me.
    Mar 2003
    214
    The flux cored wire provides it's own shielding gas by the burning of the flux. I also had really good luck with flux cored wire. I like it because it can be used outdoors with a breeze blowing. With innershield a breeze will blow away your cover gas and cause porosity. I used to weld for Busyrus Erie. We used innershield wire for high doposition rates ie: filling 1 1/2" to 6" v-groove welds. We ran the machines at a minimum of 350 amps with a maximum beed width for maximum strength 5/8" wide. I have however seen guys weld 1 1/2" wide groove welds. It's nice not to have to have the gas and I think flux cored wire rocks. Strengh wise I think they are about the same. Lincoln's NR211 wire is a good all around wire.
    Ken
  17. #17
    May 2003
    267
    I have an idea to significantly the warpage but am not sure if it will work. I was thinking of temporarily clamping a thick metal plate (say 1/2" or thicker) to the thinner plate being welded. The thicker plate should hold the thinner plate straight when the welds cool. After the welds cool, I can remove the thicker plate.
    My question is will this work in reducing the warpage?
    Thanks,
  18. #18
    Mar 2003
    4826
    George,
    Yes that will help. The forces are tremendously high as the hot zone cools, though, so it takes some really good clamps to really hold the parts together.
  1. This is serious... Need advice FAST!
    By Rekd in forum Community Club House
    Last Post: 05-16-2005, 06:02 PM
  2. welding thick stuff to thin stuff - need advice
    By cross6 in forum Welding Brazing Soldering Sealing
    Last Post: 01-13-2005, 08:39 AM
  3. Welding causing hardened metal?
    By InsaneEPP in forum Welding Brazing Soldering Sealing
    Last Post: 11-24-2004, 05:35 PM
  4. Router Motor Advice Please
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 11-03-2004, 08:49 PM
  5. First time looking for advice
    By IM_MOOSE in forum Waterjet General Topics
    Last Post: 04-07-2004, 02:08 AM
