604,036 active members*
1,152 visitors online*
Results 1 to 11 of 11
    Oct 2003
    399
    What motor, screw and gearing should I choose?
    The short answer:
    For a smaller wood and plastic cutting machine (and maybe – maybe! – some light aluminum), several people on CNCzone seems to have had success with 100-200 oz-in (0.7-1.4 Nm) stepper motors direct driving a 5 turns/inch (5 mm lead) ACME (trapezoidal) screw.
    The long answer:
    ... hopefully you can find in the attached file. Please, if you spot any errors or have trouble viewing the file (like missing characters or fonts), write a comment in this thread: http://cnczone.com/forums/showthread.php?t=5639, or use the email address in the file to notify me. Other comments are also welcome to my email address.
    Arvid
    Attached Files Attached Files
    Jan 2004
    379
    Very good reading material Arvid,
    I'm going to have to look up the data sheet information for my steppers now.
    Maybe one of you have already done so and could post the specs. The steppers are from a few old HP Laserjet III's
    LABELED: Astrosyn
    TYPE: 23LM-C701-01
    P/N: RH7-1048 04
    5.2 V/Phase
    1.4 A/Phase
    1.8 Degree/Step
    Dec 2004
    1137
    First, thank you for this document. Second, this may be a newbie thing to do, but there may be a typo in your PDF.
    For the power equation you specify that it's force times speed (or velocity) but you write it at Force times distance F * s instead of F * v
    Third, I am creating a spreadsheet of the equations as a tool, and ifthere is any interest I can make a web form. We'll see.
    Jay
    Jan 2005
    55
    Web-accessible info
    Jay,
    It would be great to have that kind of information available if it's not already on this site.
    Oct 2004
    727
    LABELED: Astrosyn
    TYPE: 23LM-C701-01
    P/N: RH7-1048 04
    5.2 V/Phase
    1.4 A/Phase
    1.8 Degree/Step
    Check out the attached PDF for specs, pictures, internal wiring, etc. I hope this helps...
    Jan 2008
    5
    I have this Stepper motor and have tryed it using my Sherline mini Mill.
    The following plastics were tryed:
    Delrin Great at slow feed rate
    Acrylic nice finish but needs lubrification(I use 10W30 motor oil)
    Lexan Great at slow feed rate might be ok to mill at higher feeds if lubricant is used.
    This motor does not have the force to feed a larger end mill(Grizzly 1005).
    Mar 2007
    137
    I have retrofit over 300 milling machines, and the only thing i can say to you is, there is not that much cost differance between a 200 oz in stepper and larger ones. Go with as large of one as fits your machine and budject. dont risk going to small.
    Mar 2010
    Thats really great, I have also visited many other forums but this one is best of all
    John
    Apr 2010
    no, there is no correction to this board. It is apparetly flawed and not useable in the first place. The actual linistepper board, with it's open source layout, source code, and design DOES work. Please do not be confused by the problems afferriers had with this board. The actual linistepper board has NO problems; it works just fine.
    marry
    Jan 2009
    396
    pease help,
    I would like to know what kind of servo motor do I need to achieve 700IPM and what rack n pinion size do I need at 3 meter length? and also gearing etc
    thank you in advance guys.
    Jan 2009
    396
    please help,
    I want to be able to jog at 700IPM at 3 meter length probably going to use rack n pinion system and prefferable a servo motor. can you guys tell me the spec for servo motor and also the rack n pinion and gearing?
  1. What motor, screw and gearing should I choose? v1.2
    By arvidb in forum FAQ of DIY CNC Machine Building
    Last Post: 03-09-2015, 12:47 PM
  2. Help with formulas for gearing servos
    By cnctoolman in forum Benchtop Machines
    Last Post: 04-08-2005, 03:13 AM
  3. What motor, screw and gearing should I chose?
    By arvidb in forum DIY CNC Router Table Machines
    Last Post: 09-03-2004, 10:08 PM
  4. Reduction Gearing & Backlash
    By UKRobotics in forum DIY CNC Router Table Machines
    Last Post: 04-02-2004, 08:31 PM
