603,316 active members*
2,382 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > What's the different between a CNC Swiss Lathe and a regular CNC lathe?
Results 1 to 4 of 4
    May 2007
    320
    I'm just wondering what's the difference between these two? I am familar with a regular CNC lathe that has a 3,4, or 6 jaw chuck that you manually put the material into. For instance our machinist uses a Trak Lathe with an 8-tool square turret.
    Jul 2004
    601
    A swiss lathe moves the stock instead of the tool. This works well for thin pieces, as the cutting happens close to the chuck.
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Oct 2007
    106
    The swiss type lathes I know use a collet to grab the stock (like the chuck) and a guide bushing to hold the material close to the tool, thus avoiding deflection while cutting.
    Oct 2007
    32
    Check out www.cma-citizen.com, they offer both Swiss and conventional lathes.
  1. Converting my Engine Lathe to an 8-Station Turret Lathe!
    By widgitmaster in forum Uncategorised MetalWorking Machines
    Last Post: 08-09-2018, 04:56 PM
  2. swiss lathe tooling help
    By reddog37 in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2015, 07:43 AM
  3. Swiss Lathe, Tool Change Position
    By John3 in forum MetalWork Discussion
    Last Post: 08-07-2007, 12:46 AM
  4. Swiss Lathe Tooling?
    By solgood in forum Uncategorised MetalWorking Machines
    Last Post: 12-16-2006, 02:26 AM
  5. Anyone have a mini cnc lathe or medium sized cnc lathe
    By nymachinist in forum Mini Lathe
    Last Post: 01-24-2006, 03:36 AM
