603,311 active members*
2,011 visitors online*
IndustryArena Forum > Other Machines > Digitizing and Laser Digitizing > Where can I buy "microscribe" but longer arms ?
Results 1 to 8 of 8
    Feb 2005
    234
    looking for digitizing coordinate like Microscribe but they only have short arms, I'm looking for longer arm that can reach a car's length at once ?
    any website for this company ? no need laser CMM, very costly.
    regards
    ruddy
    May 2003
    340
    Aug 2005
    21
    I know this reply is a few months late, but I'm new
    There are a few brands of contact probes - Faro was mentioned above, Romer is another common brand. The larger arms can loose accuracy. One company placed the arm on a linear rail so that it could reach further. You may find used arms around - but make sure to contact the manufacturer to check if all the software licenses are still valid.
    Generally, people will just glue a few spheres on the vehicle and measure them; then move the arm to a different position and re-measure the spheres. The sphere centers can be used to transform the different arm positions to a common coordinate system.
    Henry
    Feb 2005
    234
    can you explain in drawing about the spheres ?
    actually what I'm looking for is Faro 3d digitizer with low price like US$ 7000 or someting.
    so far it cost US$ 20.000.
    about the sphere looks cheap but is it accurate ? how accurate ?
    regards
    rud
    Aug 2005
    21
    The spheres are just an easy way to put data from different arm positions into the same space. Don't make fun of my diagram... if you put the arm at position 1 and measure whatever you can reach including the spheres on the hood and body side. Then move to position 2 and measure the same spheres on the body side, etc. I think that most software can handle the sphere to sphere (or point to point) transformation. I believe that Rhino has support for an arm (probably Faro) and you could construct geometry as you go.
    I suppose I should have asked this question up front - what are you trying to measure and to what accuracy do you need? Accuracy cost money, but if you really need it then maybe you have to hire somebody to do the measuring instead of purchasing something that will make life difficult. It all depends on your needs.
    Henry
    Feb 2005
    234
    well my problem is this,
    I would like to make a dashboard from fibre glass.
    first I have to digitise the existing dashboard.
    my problem is I can't afford buying faro, but microscribe is fine price.
    as you know microscribe is short arms, could not reach whole dashboard to digitize.
    if I take 2 or 3 takes/position to digitize the dashbord this means accuracy will decrease, not mentionthe error.
    correct me if I'm wrong.
    regards
    ruddy
    Aug 2005
    21
    If you can reach from the left side of the dash to the right side with two positions then I would give it a try. Is there any chance that you could rent one for a day before you buy one?
    Here is one idea:
    1) remove the seats
    2) make some small metal targets about 10mm square with a very small "dimple" in them. Best if the dimple matches the diameter of the probe tip. If you have a 2mm diameter probe, then make the dimple with a 2mm ball end mill.
    3) Use a hot-glue gun to attach the targets to the car - instead of spheres
    4) The probe tip should rest in the dimple and you can record a point.
    5) Put the arm in the center of the car
    6) Measure as much as you can; but place 4 targets on the left side and four on the right side. Don't use just three in case one moves or gets measured badly
    7) move the arm to the left and to the right
    8) use the points measured from the targets to put things together
    Also, it is common to need the attachment points for the dash. So you may want to glue some targets onto the glass and any other areas that will not move (center console). Then remove the dash and measure any attachement points and obstructions that will cause you problems. The targets on the glass will help you transform the exterior of the dash into the same coordinate system as the attachment points. You should be able to make a full model from this information.
    Did I explain this so it made sense?
    Feb 2005
    234
    yes it make sense but I think microsribe won't reach the dashboard in 2 position.
    unfortunately there is no one has microsribe in my country, so sad, but they have for rent the faro arms
    it cost very expensive just to rent for one day.
    curious if microscribe won't reach dashboard in two position, what if it won't ?
    what if I need to mod. bumpers ?
    I'm sure it won;t reach in two position, say three then the accuray will go down.
    but does anyone try this ?
    how accurate ?
    it's easier to have money and buy it
    regards
    ruddy
  1. Where do you buy tooling?
    By NeoMoses in forum Community Club House
    Last Post: 03-12-2014, 03:38 PM
  2. What to buy from rutex to get going........
    By Apples in forum Rutex Products
    Last Post: 03-01-2006, 05:05 PM
  3. Oh no, What did I buy?
    By silverroller in forum CNC Machine Related Electronics
    Last Post: 03-07-2005, 06:56 PM
  4. Which stepper motor should I buy
    By Graham S in forum FAQ of DIY CNC Machine Building
    Last Post: 08-27-2004, 11:58 AM
  5. Where to buy Brass?
    By NeoMoses in forum MetalWork Discussion
    Last Post: 10-06-2003, 02:35 AM
