603,996 active members*
3,526 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Where NOT to put your toolsetter.
Results 1 to 16 of 16
    Dec 2008
    319
    I had a tool change error this evening. It happened on the change to the probe. Well I hit recover, and put something soft under the tool changer (couple of pieces of foam) and it dropped fine.... but it got the crash pin on my tool setter. I think I will move the tool setter to the opposite side of the table now.
    Tim
    Apr 2005
    713
    I've been through the recover process a few times and I have one question: Why didn't you catch the tool??
    Dec 2008
    319
    Quote Originally Posted by Matt@RFR View Post
    I put a pillow and two pieces of styrofoam down. I did not realize it would break the toolsetter so easily. I will definantly put a hard cover over the toolsetter from now on.
    Tim
    Jul 2005
    12177
    I have never had the nerve to try and catch the tool; I always use the box filled with foam rubber approach.
    I do not want to add to the collection of scars on my fingers.
    Dec 2008
    319
    Quote Originally Posted by Geof View Post
    I thought about trying to catch it but tools are cheaper than a new arm
    Jul 2003
    71
    What does the "recover" operation do? Sounds like it ejects a tool from the spindle? Or is the danger from getting one's hand between the tool changer and spindle?
    Thanks,
    Ralph
    Jul 2005
    12177
    If something happens to trigger an alarm during a toolchange the machine stops. Then when the alarm is cleared, if the toolchanger will still function the machine may not know where things are so it may try to retract the shuttle with the spindle still down over the tool, bring the shuttle in with a full pocket and a tool in the spindle or other unpredictable behaviour.
    The Recover procedure steps through asking questions such as 'is the pocket empty', 'is there a tool in the spindle', etc., and you press N or Y for it to continue. Sometimes the spindle may be partly retracted from putting a tool in the pocket and this tool may fall out or get knocked out when the spindle moves so it is a good idea to put something under it.
    When it is a case of the spindle over a tool in the pocket it is risky to get your hand near because you cannot guarantee it will not kick sideways when things move.
    Apr 2005
    713
    I see the confusion. I have a side mount tool changer and it sounds like it's much less risky to hold the tool during the recover process.
    With a SMTC, you manually (repeatedly pushing the ATC forward/reverse button) move the arm back to its home. I think it's in 1º incriments so it's easy to see if there is a bad situation developing. Plus, if there's any unordinary loads on the arm, you can see that the arm is slightly bent so you know to be more cautious.
    Dec 2008
    319
    Finally got my Marposs manual today.
    In the directions it says "it is a good idea to mount your toolsetter on the right side of the table away from your tool changer"
    Oh well.....
    Apr 2005
    713
    Quote Originally Posted by behindpropeller View Post
    Oh well.....
    That's great, but where's the 4th axis go then?
    If you're worried about it, I'm tempted to think that the better solution is to make a simple protective cover for your toolsetter.
    Jul 2003
    71
    Geof, Thanks for the clear description of tool recovery.
    I don't have a CNC yet but there will be a Haas in my garage sometime in the future. Probably one of the older "plastic" machines due to $$.
    I'm hanging out on a couple of CNC forums trying to learn whatever I can in the meantime.
    Ralph
    Dec 2008
    319
    Made a cover last night. Obviously I am very green at setting up and operating cnc machines. Most of my previous machining was R+D and hobbies with a bridgeport.
    Tim
    Dec 2006
    447
    The idea here was to keep the worst of the coolant and chip spray off the setter. I guess it would "resist" a falling tool
    Vern
    Jul 2005
    12177
    I keep my toolsetter outside the machine completely safe from coolant, chips and falling tools.
    Dec 2006
    447
    And I'll bet it didn't cost you five grand either
    Jul 2005
    12177
    Quote Originally Posted by Vern Smith View Post
    A disadvantage is that if I do smash a tool into it and damage it beyond repair I cannot get another one at any price.
  1. Help with Gcode for toolsetter
    By Harryman in forum WinCnc
    Last Post: 01-10-2009, 06:00 PM
  2. Toolsetter problems
    By inertialabs in forum Haas Mills
    Last Post: 10-23-2008, 08:51 PM
  3. Probe and toolsetter suggestions?
    By REVCAM_Bob in forum Uncategorised MetalWorking Machines
    Last Post: 01-01-2008, 01:12 AM
  4. Building Touch Probe and Toolsetter...
    By REVCAM_Bob in forum CNC Machine Related Electronics
    Last Post: 05-23-2007, 12:43 PM
  5. Mazak / Yasnak MX3 control toolsetter
    By soszi1950 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-10-2007, 03:24 PM
