603,337 active members*
3,500 visitors online*
    Jul 2008
    340
    Why can't I loft cut?
    I'm trying to create a "quick" part to use as a work clamp. The design is pretty simple, yet I cannot get Alibre to do the loft cut between two sketches through an extrusion.
    I suspect I have created the part incorrectly. Could someone look at it and tell me what I'm doing wrong?
    When I try to create the loft I select the loft cut tool, then obround objects in Sketch3 and Sketch2. I would expect the cut to go from the bottom obround object to the top obround object. I get an X on the loft feature and when I check the status it says, "ACISERROR_INVALID_BODY_RESULT: Operation - The Feature results in an invalid Body."
    -Freeman (Analias)
    Attached Files Attached Files
    Jan 2012
    47
    Try creating the sketches you are going to loft out of discrete lines and curve geometries, do not use pre-made shapes, and make sure each sits on its own plane.
    cheers
    Alan
  1. Solidworks 3D Help with Loft or Boundary Boss
    By Johnsnd in forum Solidworks
    Last Post: 02-19-2012, 05:04 PM
  2. Can anyone help me use the loft boss...
    By cloverfield333 in forum Solidworks
    Last Post: 07-24-2009, 11:14 PM
  3. Zero thickness in cut loft
    By Michael El in forum Solidworks
    Last Post: 06-18-2008, 10:58 PM
  4. my college loft
    By zachjowi in forum WoodWorking Topics
    Last Post: 01-21-2008, 04:38 AM
  5. modifying a loft
    By PTcutter in forum Solidworks
    Last Post: 06-18-2005, 01:22 AM
