587,600 active members*
4,407 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Wiring an inverter to UK mains ring
Results 1 to 9 of 9
    Dec 2010
    337
    picture attached...
    Ok, so in a frenzy I bought an inverter for my spindle thinking that i'd stick a plug on it. Failing to take into account all sorts of things that i should have done. :/
    Anyway. The inverter manufacturer recommends a 24Amp fuse (which is more than a standard 13amp home plug). So i'm going to build the inverter, RFI filter and fuse/fuseholder into a cabinet.
    My question is this: Can I safely run a cable from the fuse box, out of the cabinet and straight into a home wall socket, (uk, socket ring, 30Amp).
    Also, If i put a plug on the end hardwired without a fuse, is this ok? technically speaking of course, since there is a fuse in the inverter cabinet.
    Enter the fire brigade/ laughter from electricians.
    Mar 2007
    2083
    I'd look at this industrial 32A plug and socket
    32 Amp 3 Pin Plug & Panel Socket Blue 240v Garage Workshop 1 Phase NEXTDAY £3.99 | eBay
    if you use a 32A cable to connect the plug and inverter
    the 32A circuit breaker in the consumer unit will then protect the cable and the plug and socket
    John
    Dec 2010
    337
    thanks john. I take it i'd replace the wall socket with this panel socket? Do you know of any plug and play systems. I'm trying to get away without taking the plug sockets off the wall.
    Dec 2003
    24220
    What is the HP and FLA of the motor?
    The motor draws the current, not the VFD.
    Al.
    Albert E.
    Dec 2010
    337
    hey al, it's a Chinese spindle so specs are a bit thin on the ground, but it's the 1.5kw version. 8amp it says, not sure if that's at full load. To be honest i'm a bit bewildered by all the various ratings.
    Specs of the set up are in the pic attached below.
    edit. trying to work this out logically.. on the inverter side of things, printed on the front is a rating of 17.5A input. Is this a provision for the 200% over current feature?
    Dec 2003
    24220
    I don't see any reason for not being able to run off a ring main socket with that size of motor?
    VFD's have a over current limit that automatically shuts down if the motor load is exceeded.
    I think I mentioned in another link about the minimum rpm for these spindles.
    Al.
    Albert E.
    Dec 2010
    337
    aye, i was going to set the minimum freq to approx. 133Hz, which equates to about 8000rpm. Maybe experiment and drop it to about 100Hz. The chinese spisnlde thread here was good also, but i have to admit im only 65 pages in to it so far.
    I'm going to give the VFD distributors a call monday ask them to explain a few things, they are extremely helpful, and even knocked £200 off my VFD as the one i wanted wasn't in stock. I couldn't believe it.
    Do you have any idea about the difference in current one side of the vfd to the other. ie if the motor is drawing 8amps at a point in time, how much would be comming out the wall to feed it? I know energy is lost inbetween as heat, but there must be plenty of other factors involved.
    Dec 2003
    24220
    A VFD basically consists of a 3phase rectifier and a DC capacitor bank, which stores energy, which is then switched through to the motor, so there is very little difference between input and output.
    The electronics of the VFD does not consume that much.
    Al.
    Albert E.
    Dec 2010
    337
    ta, as a temporary measure I managed to hook it up with a fused 13amp plug and some 20amp cable which seems to have done the trick.
  1. Using USA 110V Equipment on Euro 220V Mains!
    By diarmaid in forum CNC Machine Related Electronics
    Last Post: 09-07-2021, 11:54 AM
  2. Motor rated at 170VAC 95A. Mains 400VAC.
    By fomaz in forum Phase Converters
    Last Post: 01-13-2013, 06:46 PM
  3. Ajax 3rd party to Mitsubishi inverter - Need Wiring Help!
    By nvdave in forum Centroid CNC Control Products
    Last Post: 01-25-2011, 12:08 AM
  4. 120volt 50 Hz mains input
    By Jason Marsha in forum Gecko Drives
    Last Post: 04-04-2010, 04:21 PM
  5. Mains Noise
    By Mooser in forum Gecko Drives
    Last Post: 10-16-2009, 02:46 AM
