Hi Guys
I have drawn this worm gear and would like to machine it on a Doosan 2000sy with live tooling and y axis. In mastercam what toolpath would be best using the live tooling with a 1/4" ballnose end mill. Can a C axis tool path read from a solid model? I have tried using mill muti axis flow tool path with the best results, but the dam tool only wants to feed down one angle then back up the second angle, this causes way to much material for the cutter. could there be a tool path that would cut multi pass's for the width then step down to clear all the material first?
The gear is 5" dia x 1.25 pitch.
Any help would be great
