587,775 active members*
2,712 visitors online*
Results 1 to 14 of 14
    Jun 2004
    450
    Lightbulb Would this interest anyone?
    An exchange of services?
    I'm currently in the process of looking for a mill. Then I have to go through the loan process(hey, I'm a working man with a family!:violin: ), purchasing tooling, etc....To be honest, it may be months, or never.
    But I'd still like to have something made. I've been working on an idea for a couple of months now. And have finally done the research into final selling prices, demand, etc. And I think I could make a bit of money off this. But I don't have the money right now to have someone make these in the quantity I would like.
    So, what I'm proposing is if you need any modeling or programming done, I have experience in Rhino3d and MasterCAM and will do a project or five. In return, I would like to have something made.
    There are 2 pieces that I need made (quantity would depend on the modeling/programming you have for me), almost identical to each other. Overall finish dims. are 10 x 4.5 x .5. Both would need to be aluminum. And I would guestimate the time for machining to be 15-20 min. total for a machine that could cut aluminum at a decent rate. I could even do the programming on them.
    Would anyone possibly be interested, or am I crazy for even thinking anyone would be interested?
    Jun 2004
    450
    Ok then, how about an RFQ for the parts? I had originally posted on a newsgroup for an RFQ, unfortunately I hadn't had all the information needed, and didn't draw much attention.
    So I did a bit more research, and a bit of redesign. And have finally came up with something final.
    I'm going to try and post pictures of just one of the pieces. The other piece is almost identical. If anyone is interested in quoting them, send me an email at [email protected] or a message here and I can send the cad file and notes on some of the dimensions and things.
    Quantity will be 100 of both pieces. Will probably need them in intervals of 20 pieces each per month. With the posibility of more after the total 100 pieces are shipped.
    And here's my attempt at posting pictures......
    Jun 2004
    450
    And bottom view....
    Mar 2003
    6855
    I'd be interested, I will PM you. What is it for and what is the tolerance?
    Jun 2004
    450
    Most tolerances will be pretty standard (+/- .01). But there are some holes that will need to be held closer. Should be able to hold them with just drilling. I doubt reaming will be needed. The surface with the pockets will need to be flat with a few thousandths. As that is where the other piece mates to. The whole thing will be polished, so surface finishes are important, but nothing I can't work around. As long as there aren't any deep scratches or dings. I'd like to have the periphery cut on both pieces at the same time (clamped together) to ensure that they will match up nicely.
    Once everything is put together, it will be an "industructable" cigar case. I know, I know.....it's destructable. But bear with me. :rainfro:
    Mar 2003
    6855
    When are you looking for these to be done by?
    Jun 2004
    450
    last month.
    Actually I would like to have a 'sample' part of each for a test fit within a month. Some changes may be needed, however they will be small changes (nothing to cause retooling). Then probably a month after that recieve the first set.
    Mar 2003
    6855
    Send me a file to [email protected]
    Feb 2004
    2337
    I would have thought that making one and then casting the others would be a more cost efficient idea.
    Being outside the square !!!
    Jun 2004
    450
    IGS format ok?
    Benny, that idea what suggested by someone else. He was supposed to call me. But never did. I'm not familiar with that process. Can a nice surface finish be achieved? Tolerances?
    Mar 2003
    6855
    igs -yes
    Feb 2004
    2337
    IGS format ok?
    I dont know about the tolerances or anything like that. But I know they make shiney jewelery this way so I guess the finish is ok. There is an artical about casting in this forum done by Splint. http://www.cnczone.com/forums/showth...&threadid=4666
    I guess you could talk to a casting company near you about costs etc.
    You will still need you original cut for you though
    Jun 2003
    453
    If you're serious about getting them cast dont do any machining until you've fully discussed your part and the casting technique with the engineer at the foundry. The patterns may need to be made slightly larger than the finished componant to allow for shrinkage as the casting cools after pouring (somewhere about 2% for aluminium but the foundry would be your best source of information on that) and machining or buffing the casting also needs to be considered as varying techniques of casting will have differing surface finishes. Speak to the guys at the foundry before you do anything.
    Cheers
    Splint
    Apr 2003
    3578
    if wants a decent finish then I would say a wax investment tool would be made.
    Follow splint on that there is a Shrink factor for investment casting.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. Replies: 86
    Last Post: 08-07-2015, 01:05 PM
  2. Any interest in cnc Boxford's?
    By greggv in forum Uncategorised MetalWorking Machines
    Last Post: 03-31-2006, 07:53 PM
  3. What are your other interest?
    By cncadmin in forum Community Club House
    Last Post: 05-23-2005, 11:11 PM
  4. Rapidly losing interest.
    By ynneb in forum Community Club House
    Last Post: 04-08-2005, 08:04 AM
  5. Thanks
    By Boss302 in forum OneCNC
    Last Post: 07-21-2004, 04:51 PM
