603,936 active members*
2,604 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > writing programs use it or loose it
Results 1 to 7 of 7
    Aug 2006
    5
    How do you move a program from mdi into memory on a Haas lathe
    Mar 2010
    1852
    Re: writing programs use it or loose it
    Type a program number in front of it and hit enter I believe.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Mar 2003
    2932
    Mar 2010
    1852
    Right, ALTER.
    I was not at the machine to try my button.
    Mike
    Aug 2006
    5
    Thanks for the answer and the attached thumbnail, i found a similar answer in the Haas manual except it shows the program number (onnnnn) the letter O and five numbers in parenthesis. It would not work when i put the program number in parenthesis. Just put in the letter O and the numbers and it worked like a charm.
    Aug 2006
    5
    Yep, cursor to top of program
    enter prog#
    ALTER
    Mar 2010
    1852
    Quote Originally Posted by vmc4020 View Post
    Yep, it's funny that the writers are always putting things in parentheses or quotes to add significance to the words or numbers and that just messes us up!
  1. Writing programs on a 5020L Control
    By vanbry in forum Okuma
    Last Post: 08-12-2009, 02:07 PM
  2. please help before i loose my mind :(
    By markraws in forum Stepper Motors / Drives
    Last Post: 03-30-2008, 05:22 PM
  3. loose column on h-400
    By TACKER in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-11-2007, 02:04 PM
  4. Loose Spindle nut
    By highhat in forum Benchtop Machines
    Last Post: 09-01-2006, 09:18 PM
