587,517 active members*
3,471 visitors online*
Results 1 to 5 of 5
    Jan 2010
    29
    X Axis machining off centre
    Hi Guys,
    I'm throwing my hand up here for help. You know, like a guy who is drowning and going down for the 3rd time.
    I seem to have developed a problem (well I've never noticed before in 18 months of cnc work) but a job I am currently working on seems to be machining off centre.
    Scenario:
    • 4 axis machine
    • Machining a 4 sided (flat) object
    • Designed in Rhinocam. (Have confirmed all machining co-ordinates are set to 0 axis). Simulated output of job is perfect. No abnormalities detected.
    • Using Mach 3. (Have checked and confirmed that no tool 'offsets' have been programmed into code.) To the best of my knowledge anyhow.
    • Rotation axis at X
    Problem:
    • When I machine the 4 sides at 0, 90, 180 and 270 degrees, the centre of machining along the X axis is off line by approx. 3mm (0.125") on all 4 sides.
    I have attached a copy of the Mach 3 Code setup, which seems fine, BUT I could be misunderstanding something.
    Any suggestions would be extremely welcomed.
    Thanks in advance
    Phil
    Sep 2012
    1543
    Is your zero correct in mach3 and RhinoCam, do they match?
    Jan 2010
    29
    Problem solved...I think.
    I reset WCS and re-aligned Part and Stock (which I'm sure I've already done???) in Rhinocam and noticed the part display jump about 2mm right of Y axis. (Measuring the last physically machined unit I did, 2mm offset would be pretty correct)
    So BAMCNC.com....thanks mate I think you were on the right track, as I hadn't seen your post beforehand. Thanks for your reply.
    Sadly I'm, still confused as to what was (obviously) misaligned and why.
    Just hope my next 8 hour machine run turns out OK.
    Sep 2012
    1543
    I've had it happen before, due to aligning, then drawing, or aligning then changing stock size. I make it a point to re-align before I POST.
    Jan 2010
    29
    to BAMCNC.com
    Again thanks for your assistance. If you get a moment I have now another issue I'm trying to resolve with this task which you may be able to enlighten me upon which I would welcome. I have posted it into another Topic which is:
    http://www.cnczone.com/forums/artcam...ml#post1197429
    Again any assistance would be great.
    Phil
  1. Help on indentifying this machining centre..
    By hub in forum Uncategorised MetalWorking Machines
    Last Post: 11-01-2011, 07:10 PM
  2. possible benchtop machining centre
    By manley86 in forum Vertical Mill, Lathe Project Log
    Last Post: 06-12-2010, 01:40 PM
  3. Formula for B axis rotation on machining centre?
    By fitzpatrick2362 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-25-2009, 04:36 AM
  4. 5 Axis Machining and 6 Axes Turning Centre available
    By syamin in forum News Announcements
    Last Post: 02-16-2009, 01:25 AM
