587,132 active members*
3,071 visitors online*
IndustryArena Forum > CAM Software > Mastercam > X3 - Can I copy/replicate geometry *and* the associated toolpaths?
Results 1 to 4 of 4
Hybrid View
    Jul 2008
    139
    Let's say I create a part in Mastercam...ie create the geometry in CAD then the associated tool operations to cut/dril it out..
    Can this part then be panelised .....ie more copies of the part on the same stock, but copied along with the toolpaths created for the original part?(else that's a lot of work then having to add all the toolpaths on the copied gemetry!)
    if so, how is it done in practise? (or do folks just use a G-code offset to produce the same part over & over on the same stock?
    Dec 2006
    116
    Use tool path transform, enter parameters and hit go.
    WANNA GO FASTER
    Dec 2008
    3122
    Quote Originally Posted by HankMcSpank View Post
    Yes, but it is better to transform just the paths
    ( editing the original geometry or operation, affects the entire transformed paths )( ghost the original ops, and post the transformed paths )
    You can transform the toolpath onto itself,,,,but have it assign a different offset for each repeat. This is good if using subs ---> ie take up new work offset then call sub, shorter prog, easier to edit on control
    -you can transform into your array, AND have only 1 work offset OR a seperate offset for each ( this can create long programs, and be long winded in proving out )
    Apr 2003
    3578
    Are you asking for nesting option or just make a few copys?
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. Replies: 6
    Last Post: 03-14-2011, 09:41 PM
  2. v23 will not select wireframe geometry for toolpaths???
    By Frantic Fab in forum BobCad-Cam
    Last Post: 01-08-2011, 11:20 PM
  3. Geometry from NC
    By rherman in forum BobCad-Cam
    Last Post: 09-21-2006, 01:10 PM
  4. Associated toolpaths and geometry
    By Paul G. Swartz in forum Surfcam
    Last Post: 09-12-2006, 05:42 PM
  5. The X-Axles... to move or not to move!
    By Wild4aces in forum Mechanical Calculations/Engineering Design
    Last Post: 03-18-2005, 08:26 PM
