588,150 active members*
5,289 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > X4+ start first time, estop Spindle trouble
Results 1 to 5 of 5
    Jan 2012
    74
    Unhappy X4+ start first time, estop Spindle trouble
    Hi
    Yesterday I had started the machine for the first time
    when i switched on the machine, the display shows E-Stop
    after releasing the Emergency stop the message E-Stop allways appears
    Only when I disconnect the signal cable (2 wires) for the five axis board, the message "E-Stop" disappears in the display
    now I can move the axis X, Y, Z and turn on the coolant but the spindle doesn't turn on.
    The display always shows 0 RPM even when I turn the rotary switch and
    press the "spindle" button
Name:	switch does not work .png
Name:	Spindle doesn't turn.png
    when I connect the signal cable (2 wires) once again , the message E-Stop in the display appears and nothing works.
    i have already tried a different emergency switch, without success
    Jan 2012
    74
    has nobody an idea? :idea:
    Very frustrating to buy a new machine and then it doesn't work!
    Jan 2012
    74
    Smile [FIXED]
    Hi
    i have solved the problem!
    Yesterday I disconnected all wires in the control and checked all the terminals and connectors (replaced some loose and sloppy).
    Then I reconnected everything with the help of the manual (Unfortunately, the manual is very vague and sometimes incomplete)
    Now everything works
    Next things i want to do are to modify some things (add power drawbar, an enclosure mounted on the stand, add workpiece touch probe and a Tool touch probe, add MQL)
    Apr 2006
    844
    good....any questions let us konw or sent email to [email protected]
    Direction,Commitment,Follow through
    Jun 2007
    3735
    Give all crimped wires a tug, and ensure screws are tight.
    Make sure shaft couplers are tightened properly.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
  1. estop triggers when spindle is turned on
    By bbuonomo in forum Tormach Personal CNC Mill
    Last Post: 10-01-2016, 08:39 PM
  2. Syil x5 spindle estop trouble
    By AussiHorologist in forum Syil Products
    Last Post: 12-31-2011, 10:35 PM
  3. Trouble homing TL-2 on start up.
    By Greg Benedict in forum Haas Lathes
    Last Post: 08-28-2009, 04:09 AM
  4. Pendant for cycle start, feed hold and estop?
    By Alex_Cole in forum Mach Software (ArtSoft software)
    Last Post: 11-08-2007, 01:10 AM
  5. Spindle Start Time out
    By JonLed in forum Fanuc
    Last Post: 03-17-2006, 07:00 AM
