603,939 active members*
1,666 visitors online*
IndustryArena Forum > CAM Software > OneCNC > XR7 Mill Pro and multi vise fixture - help!
    Apr 2006
    19
    I am running a Fadal 3016 with XR7 Mill Pro.
    I have a nice multi vise fixture set up with 6 pcs ready to go and a complicated program to get running.
    I need to use the multi vise, multi offsets type of repeat.
    I am struggling a bit with the Post set up.
    Two things I can't figure out:
    1. The Post automatically starts numbering subroutines starting from 100.
    The Fadal control can only accept subs numbered from 01 to 89.
    Is there a way to fix the sub numbering provided by the Post? Or can I do math within the Post to fix this such as {(RN-99)} instead of {RN}?
    2. The Post puts the main program at the beginning of the NC listing and the subroutines at the end.
    The Fadal control requires the subs to be at the beginning of the listing and the main program to follow the subs.
    Is there a way to control this output to get the subs listed at the beginning?
    Thanks for any help (I'm stuck with manual editing on a giant program if I can't figure this out!)
    RC
    Apr 2006
    19
    Re: XR7 Mill Pro and multi vise fixture - help!
    I figured it out.
    Thanks!
    RC
  1. multi part fixture reference
    By Uman in forum Tormach Personal CNC Mill
    Last Post: 03-07-2017, 03:21 PM
  2. Multi Vise Machining
    By kutter in forum CamWorks
    Last Post: 04-23-2014, 04:32 PM
  3. Multi-Part Self Adjusting Vise Jaw
    By l u k e in forum Work Fixtures / Hold-Down Solutions
    Last Post: 02-19-2014, 06:09 PM
  4. Help with multi-part fixture
    By Pharkas in forum MetalWork Discussion
    Last Post: 09-12-2012, 04:07 PM
  5. Multi fixture issues
    By durgam605 in forum FeatureCAM CAD/CAM
    Last Post: 07-01-2011, 01:54 PM
