[ame=http://www.youtube.com/watch?v=RPRCWOfmirU]cnc router with Xbox control.mov - YouTube[/ame]
XZero cnc
see update: post #3017 http://www.cnczone.com/forums/1204588-post3017.html George: What Happened at minute 3.48? CNC Milling CedarWood- video
Cable drag chain:
must be in your gcode, cause it doesnt look like it lost position or stalled.
What does speed of machine have to do with 3d printing? All you need is the extrusion head; which you can buy online and some plastic. Slap that on your xzero and POW! you got yourself a 3d printer.
Here is some printer speeds i could find
XZero cnc
You can also run belt and pulley set up and belt it up 2 to 1 and get super fast
XZero cnc
Also changing stepper motors to high quality steppers and not china steppers also would make big difference in speed as far as stalling
XZero cnc
Here is pictures of updated Z axis, one pieces front plate. Little more room for adjustment in ballscrews. More clearance now for prox switch
XZero cnc
Hope shortly to have a bit more info on steel framed Raptor and Demon machines
XZero cnc
The estuctural frame, finished.!
The Painting small parts: red and aluminum (smooth shiny).
Here CENTROID CNC controller turnkey and will have video running machine shortly.
Have 3 to 1 pulley set ups also for machine or would run over 3000ipm.
CENTROID CNC controls,CNC Retrofits,CNC Milling Machines,CNC Lathes,CNC Routers,5 Axis CNC Cylinder Head Porting Machines,CNC Rotary Tables,Fanuc Retrofits,Digitizing Probes,Conversational Programming
XZero cnc
Have also a new 4x4 in 3 styles, profile rails and steel machine will be turnkey.
have a new style not turnkey 4x4 or longer with dual ballscrews and supported railing that will be under $4000. All parts are hidden and no parts will be unprotected .Could use for CNC router and also plasma or laser
XZero cnc
The yellow cable chain, is original. I bought it on ebay... 3 years ago.
http://www.youtube.com/v/cVpuQwudbrg See the minute: 5.35.
XZero cnc
