587,166 active members*
3,988 visitors online*
    Apr 2009
    31
    yaskawa servo drive
    hi all
    i need your help for my yaskawa servo driver problems .
    frist of the problem when the boy made wrong wire connection , he gives one one of the sensors on the machine 3 phases (380V) and powering on machine ... it had to boom and the main power shut down .
    we found many corrupted resistors and relays in the operator board and main control board ... we change it .
    some changing happened in solve problem direction .
    but now i have no move for all axis and if i try it i get alarm ( over servo lag )
    and i have signal in all servo drivers screen ... it means ( difference between the motor speed and reference speed is below preset value )
    pls. can you tell me what's possible was happend when the sensor was take 380v
    and now what i can solve it .
    its urgent pls.
    Dec 2003
    24223
    There is obviously something still blown on the board the sensor was connected to, could be a power supply or burnt traces, almost immposible to diagnose this kind of problem from a distance.
    Al.
    Albert E.
    Apr 2009
    31
    hi al.
    thanks for your reply .
    so , you mean we must check the all board in machine or servo driver board ?
    and if you know any thing about this problem and it solve pls. tell me how i can ?
    and if i can get technical support from yaskawa in egypt ... r u know it ?
    pls. following with me
  1. Yaskawa SGDH and SGDA servo motor/drive wiring questions
    By rpseguin in forum Servo Motors / Drives
    Last Post: 08-30-2021, 04:57 PM
  2. Trouble with Yaskawa Drive & Servo
    By curtisturner in forum Servo Motors / Drives
    Last Post: 04-28-2011, 06:57 AM
  3. Running Yaskawa drive with RPC
    By ticica in forum Phase Converters
    Last Post: 04-26-2009, 01:59 AM
  4. Yaskawa Drive + Pixie 100
    Last Post: 08-08-2007, 05:06 AM
  5. problem with Yaskawa V7 drive
    By rebrumm in forum Phase Converters
    Last Post: 05-22-2006, 10:40 PM
