603,832 active members*
4,510 visitors online*
Results 1 to 4 of 4
    Dec 2004
    12
    z Axis reversed - Resolved
    Home made setup. Just starting to get it working.
    If the z axis is at 0,
    when I send
    g01 z5
    z travels down instead of up.
    I am not keen to plunge into the cabling and electronics.
    Is there a quick way to reverse the z axis direction in Mach3?
    TIA
    Jim
    Jan 2005
    9
    you can go into pinouts config and check "low" and it'll reverse direction. I've only started using it yesterday, so certainly not an expert, but it worked for me yesterday when I had to do it.
    Dec 2004
    12
    Smile Fixed
    CncAgain
    That fixed it. Thanks
    Mar 2003
    35494
    Under Homing/Limits, check the "reverse" box.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. g-code reversed??
    By mastertech in forum Uncategorised CAM Discussion
    Last Post: 02-26-2008, 09:20 PM
  2. Table display screen reversed?
    By bcnc in forum Mach Mill
    Last Post: 06-17-2007, 05:48 AM
  3. Y axis reversed
    By Legion99999 in forum Syil Products
    Last Post: 03-04-2007, 06:43 AM
  4. Don't hurt the noob ... 1 axis reversed, help
    By oddatwl in forum Xylotex
    Last Post: 02-14-2007, 07:35 AM
