EMO Hannover
1330
EMO Hannover
1330
G 35 – Dual-spindle machine with vertical concept really takes off
MarketingVerein Deutscher Werkzeugmaschinenfabriken e.V. on September 7, 2019 at 5:00 PM
With the Oerlikon G 35 Bevel Gear Grinding Machine, KLINGELNBERG has implemented a new machine design for the 5-cut method. As a result, the manufacture of aviation gearing as regards efficiency is really taking off. To achieve this, the system provider has combined proven technology with new ideas. Background: bevel gears manufactured using the 5-cut method with a fixed setting are used in the aviation industry. This entails the consecutive machining of convex and concave pinion flanks, with different tools and different machine settings. Due to complex certification procedures for aerospace applications, changing to another gearing is not an option. However, the newly developed Oerlikon G 35 Bevel Gear Grinding Machine makes the production of aerospace gearings much more efficient thanks to its technology: with its two vertically arranged grinding spindles, it is specially tailored to these requirements. In contrast to older dual-spindle concepts with fixed grinding spindles, the G 35 is equipped with two grinding heads that are positionable independently of each other, thus enabling maximum flexibility.
