EMO Hannover
1330
EMO Hannover
1330
More clearance, more power - EMCO shows the HYPERTURN 65 Powermill at EMO 2019
MarketingVerein Deutscher Werkzeugmaschinenfabriken e.V. on September 5, 2019 at 10:00 AM
With the new HYPERTURN 65 Powermill, EMCO's brand promise, “beyond standard”, is now also successfully reflected in the machine design.
With a spindle distance of 1400 mm for high flexibility, a maximum tool length of 350 mm, a tool weight of up to 12 kg for deeper boreholes and larger tool heads as well as a programmable mini gantry for the automatic unloading of finished parts, the latest Hyperturn 65 Powermill is the successful follow-up of the well-established Hyperturn series.
A powerful counter spindle allows for 4-axis machining, and a B-axis with direct drive makes it possible to perform simultaneous 5-axis milling operations on complex parts.  The machine is moreover equipped with a Y-axis for the lower turret.
Complex and sophisticated turning, drilling, milling and gear cutting operations can be carried out in only one work process; there is no need for re-clamping or temporary storage. The workpiece precision is enormously improved, whereas it is possible to reduce the overall production times, the space requirements, the tooling expenses and the personnel costs to a significant extent.
With 22 kW, 60 Nm and 12000 rpm, the milling spindle is a top performer when it comes to high productivity in the complete machining of complex workpieces.  Thanks to its directly driven B-axis, the Hyperturn 65 PM achieves high dynamics and contour accuracy in simultaneous 5-axis machining.  The non-productive times related to tool changes are reduced as well.
The 40-, 80- or 120-station tool magazines with HSK-T63 offer more options for complex complete machining- with low set-up requirements in the manufacture of individual parts and high stability in turning and milling operations.  The integrated tool magazine does not need to be disassembled for transport purposes, which results in shorter commissioning times and reduced transport costs.
 Thanks to its new design, the Hyperturn 65 Powermill has been upgraded both functionally and visually.  The machine is particularly suitable for the series production of workpieces, e.g. in the automotive, aircraft and engineering industries or the area of fastening technology.
