588,528 active members*
6,540 visitors online*
Thread: 18i-mb helix
Results 1 to 7 of 7
    Jun 2008
    6
    18i-mb helix
    We just got a new Yama Seiki Mill with the 18i-mb controller on it. We are trying to rough a id with a helix. We have tried using an edgecam program and a program that we wrote longhand. When it is running, you can watch your x and y values increase with each revolution that it makes, like it is doing a spiral. It is feeding down in the z correctly, but just wont stay on course in the x and y. This controller has conical, spiral and helical interpolation on. Anybody else had this problem?
    Mar 2003
    2932
    Could you post that section of code so we might see what's wrong and possibly offer some assistance?
    Jun 2008
    6
    T2 M6
    G00 G54 G90 X0. Y0. S2500 M3
    G43 H2 Z.1 D2
    G00 G41 X4.225
    G1 Z.005 F10.
    G3 X4.225 I-4.225 Z-.985 L10 F300.
    G3 X4.225 I-4.225
    G00 Z1.
    G40
    M9
    G91 G28 Z0.
    G91 G28 Z0.
    M30
    Thanks for your help!!
    Mar 2003
    2932
    Several thoughts:
    Do you really mean to be helixing -.985 in Z each time around, or 0.985 total depth?
    I don't see in the 18i-MB Operators Manual that L is a valid "repeat" command... you may have to do this in a sub with a repeat value.
    T2 M6
    G43 H2 Z.1 D2
    G00 G41 X4.225
    G1 Z.005 F10.
    M98 P0102005 (REJPEAT SUB 2005 10 TIMES)
    G3 I-4.225 (ONE PASS AT FINAL DEPTH)
    G00 G90 Z1.
    G40
    M9
    G91 G28 Z0.
    G91 G28 Z0.
    M30
    O2005(HELICAL SUB)
    G91 G3 I-4.225 Z-.0985 F300.
    M99
    Jun 2008
    6
    z-.985 is the final z depth. It's worked with this machine putting the final z depth and then the L number is the number of rev's it makes to get to that, producing a cut increment of .0985. I'll try this sub program and see what it does. I greatly appreciate it!!!
    Jun 2008
    7
    Can you change your post or CAM settings to output small point to point moves? This is how I've always done it.
    Jun 2008
    6
    The sub program worked. I just don't know if I can get Edgecam to output the program that way. Hard telling. Thanks for your help guys!
  1. trying to program a helix...
    By WRMorrison in forum FeatureCAM CAD/CAM
    Last Post: 04-03-2008, 05:34 AM
  2. Helix in SWX 2008
    By pixburghenat in forum Solidworks
    Last Post: 03-24-2008, 04:07 AM
  3. make helix
    By mcfelix in forum MetalWork Discussion
    Last Post: 04-07-2006, 09:39 PM
  4. Pattern around a helix
    By posix in forum Solidworks
    Last Post: 10-07-2005, 08:57 PM
  5. How To Use G06 G07 Helix
    By PROTOTRAKFAN in forum G-Code Programing
    Last Post: 06-26-2005, 02:54 PM
