588,167 active members*
4,575 visitors online*
    Nov 2007
    Question 2.5 Axis Direction Control
    I've got a 2.5 axis PCB engraving table. The Z-axis is controlled by a solenoid and the X and Y axes are controlled by stepper motors. I'd like to use the Z-axis direction pin to control the up/down motion of the solenoid. In the standard stepper configuration, the Z-axis direction always returns to a logic zero when the stepping is completed. Does anyone know of a way to make the direction "stick" after the stepping is completed?
    Thanks in advance.
    Dec 2005
    94
    Okay, I take it this is one you are building and not one you've bought.
    Since the direction last seen when a step was taken is the 'real' current direction, you might use a bit of logic circuitry to make the direction bit 'stick'.. I think, using a Type D flip flop with the step connected to the 'clock' line and the direction connected to the 'input' line would do it, and use the 'd' output line to drive the solenoid.
    Natch, you are going to need some stuff along with that, like.. a logicl level mosfet for controlling the current to the solenoid, and perhaps some transistors to help buffer the inputs, or maybe just 5 volt zeners to clamp the inputs to logic levels might do it.
    Good luck.
    Jul 2003
    1760
    Look at emc2's hal layer. I bet you could do it pretty easy in that.
    Do you need to use z? could it be an M code? one for up - one for down?
    Either way - it should be pretty easy to do.
    sam
  1. A axis direction change?
    By nervis1 in forum Fadal
    Last Post: 10-27-2006, 04:49 PM
  2. Step and direction info on M control
    By colin1544 in forum Centroid CNC Control Products
    Last Post: 05-31-2006, 02:00 PM
  3. step and direction control for opto22 servo drive
    By drewgarth in forum Servo Motors / Drives
    Last Post: 05-21-2006, 07:31 PM
  4. Reverse axis direction?
    By saturnnights in forum Machines running Mach Software
    Last Post: 03-29-2006, 03:40 AM
  5. z axis direction question.
    By ljoe1969 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-22-2004, 02:53 AM
