587,765 active members*
3,508 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Can not go to home after pressing RESET button? ????
Results 1 to 5 of 5
    Feb 2004
    427
    If I click the on screen RESET button in Mach3, then click it again so that it is not on anymore. Then when I click on the go to home button the machine will not start moving to the home 0,0,0 positions.
    It only does that if you hit the reset button.
    Is that normal, is that how it is meant to be?
    I can manually jog the machine back to 0,0 via the arrow keys, but clickling on the Go to Zero button does nothing. Pressing the RESET button does something to it???
    My little site on MIG welding http://www.learn-how-to-weld.com/mig-welding/
    Jan 2005
    15362
    Re: Can not go to home after pressing RESET button? ????
    Quote Originally Posted by Apples View Post
    Are there any numbers in the Dro's when you try it, or do the Dro's all have zeros'
    Mactec54
    Feb 2004
    427
    I will have to do it again because I can not remember. I will get back to you later.
    Feb 2004
    427
    The DRO's had numbers in them. I could jog around with the arrows on keyboard and the DRO values would change, Just "go to z" not working.
    Jan 2005
    15362
    Something must of gone wrong with some files, save you XML, license and any other files you want, and reinstall
    Mactec54
  1. Replies: 1
    Last Post: 05-20-2020, 01:56 PM
  2. FP3NC - bosch PC rebooting when pressing "ON" button
    By Alex_Russia in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 02-04-2016, 07:29 PM
  3. Pressing reset changes G54 values to zero.
    By kmuller in forum Fanuc
    Last Post: 12-24-2014, 04:06 AM
  4. laser with MPC 6525 - laser blocks after pressing the START button
    By WendyL in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-27-2013, 07:39 AM
  5. Pressing Reset in Mach3 set Machine coords to 0?
    By nova24 in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-21-2012, 04:21 PM
