587,196 active members*
2,987 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Computer performance in a cold shop?
Results 1 to 15 of 15
    Aug 2008
    1166
    I'm working on finishing up a gantry router - my first cnc machine. I've got my z-axis moving under computer control on my dining room table, but soon it will end up in my unheated garage. A few days ago it was -4 degrees F in my garage. In the summer it will be about 90 degrees F. I'm not too worried about the summer - I can add fans as needed for cooling. But what about cold temperatures, specifically when I first turn on the computer when it's really cold. I did a little research and found people saying that the expansion of parts as they warm up can stress solder joints and ultimately cause things to fail. Another potential concern could be condensation. I'd rather avoid that if I can. What I was thinking about is sticking an incandescent light bulb inside my computer case and having the monitor mounted in the same case along with my stepper driver. I've used a baseboard thermostat before to switch a lightbulb on and off to make a little composite curing oven - they're only $15. In a small box like this, I would think I wouldn't have a lot of trouble maintaining a temperature around 70F.
    Am I concerned about nothing here? Does anyone here have experience using a normal PC in an unheated shop?
    Sep 2006
    245
    You are right that condensation is bad. The processor (and probably all other components in the system) are spec'ed to operate across a range of at least 0C to 90C non-condensing. This is -32F to 194F, so you should be OK.
    Steve
    Dec 2005
    21
    My concern would be Human performance at -4 .
    My shop gets down to about 40. And I thought that was cold.
    How do work in that temp?
    Cheers,
    Tom
    Sep 2006
    245
    Quote Originally Posted by steve323 View Post
    Steve
    Oops, 0C to 90C is 25F to 194F. A small heat lamp for the electronics is probably a good idea.
    -4F is really cold. I agree with Tom. How do you work in that environment? Also, how do you keep the bearings and other mechanical parts on your router from freezing?
    Steve
    Dec 2007
    379
    You gotta get some heat in there. I have had my "shop" around 40 F and at that temperature I am pretty sure my computer was quite happy. As others have mentioned, the condensation will cause problems. I have read reports on laptops in sub zero temps and their is a risk losing data because of the temps. Other problems occur such as dead pixels damaged batteries and shattered screens. I suspect a desktop will would have similar results.
    I would definately not run a computer or my machine in sub zero temps.
    Aug 2008
    1166
    Thanks guys. I am still building my router - I actually finished cutting up the pieces for my bench last night. I don't think I'd actually be outside very long in -4F temperatures, but it's conceivable I would try to get some parts running and go inside. I work out there at around 30F on a normal basis. Lots of layers, coat, hat and gloves do the trick. A dust mask keeps my face pretty warm too. I will give my thermostat and heater idea a try. As for bearings, I don't think that will be a problem but I'll set one out there tonight and see if they freeze up. Maybe heat in the garage will be a project for next winter.
    Oct 2008
    1147
    I'm an avid overclocker. Basically I take computer hardware and make it run way beyond the speeds the parts were sold to run at. PC performance wise, I'm generally 1 and half year ahead of whatever is the top of the line at the moment.
    Anyways, you will not have any problems running your pc between 0 to -20. Sometimes we use liquid nitrogen to get really high overclocks on cpu's. You'd be surprised how much happier a CPU is at -100c. That said, some of the older AMD chips had a cold bug where they didn't like tempertures under -20c. Some motherboards (rare) also will have porblems booting around 0. If it is the motherboard you may have to hit the power button a couple of times until it boots. But 99% of the time you will not have that problem.
    Condensation will not be a problem at all. For condensation to occur you need a colder item, like a glass of ice water, surrounded by warmer air so the cold glass can take the moisture from the energized air. So unless your cpu will somehow be continually colder than the freezing air, you'd make a 100 million bucks selling that trick to AMD and Intel, than condensation cannot occur.
    Same thing during the summer. Your pc will always run hotter than the ambient temperature. So condensation will not happen either. One problem that can occur, is if you left your garage door open. Then your pc will get dew on it. In that scenario, the pc will be colder from the lower temperatures in the night and when the warmer air hits it after sunrise, then, condensation can occur. But if the door is closed and things heat up and cool down at the same time, no drafts, than dew/condensation cannot occur.
    90f in the summer could be a problem. It will not kill your pc, maybe shorten it's life, but the hotter the pc components get, the more crashes you will have.
    Solder melts at 80 to 90c. Again, you will not have a problem.
    Feb 2010
    331
    x2 on everything fandz said. i have been building computers for over a decade and do all the same stuff. cold is actually good for computers. (all major businesses keep there servers and computers in rooms with the a/c set to like 60*F)
    Aug 2008
    1166
    Since we're evidently resurrecting this thread, I can ad that I've used said computer in my shop for about a year and two months now since I asked this question and have not had a problem other than the case fans sounding bad when I start it up at 20F. That and I had a monitor die, but I think that's unrelated to temp...
    Feb 2010
    331
    whoops. i looked at the date and saw 2009. i didn't realize it was the very beginning of 09. (came up in a search.)
    Aug 2008
    1166
    Nothing wrong with that. It never hurts to add more information.
    Oct 2008
    1147
    Quote Originally Posted by jsheerin View Post
    Ya know, I never thought about the monitor. Yea they don't like cold temps. You may do good wrapping it once you power it down and then pulling the blanket off when you turn it on. That way maybe it'll keep some warmth over night. I have an LCD that starts to act flaky around 40f.
    Zygoat, I'm running a completely stock pc since I got into cnc's. Just can't seem to pull my self away from cnc's long enough to go into a bios to change anything. That's how life consuming cnc's can be. And the crazy thing is overclocking is what got me looking at cnc's in the first place.lol
    Feb 2010
    331
    mine is not oc'd now. (but is pretty darn fast stock) i was waiting for a better cooler.... maybe ill cnc one! now were on to something!
    what are you running?
    Oct 2008
    1147
    Quote Originally Posted by Zygoat View Post
    AMD 955 BE, 4gig's of ddr3 1600, 2 hard drives in raid0. I made sure to get the black edition so I'd have an unlocked multiplier but I haven't touched it. It's almost like I don't see what the point would be with a quad core. All my cad programs are smooth as silk and it just munches through anything I throw at it. Kinda glad I didn't get a core i7. Everyone complains how bloated win7 and vista are but it's almost like hardware is beyond software at this point. All we need are SSD's to take a nose dive in price.
    So what you packing?
    Feb 2010
    331
    win 7 is way better than vista was. i know that.
    amd 965 black edition
    8gb ram
    2 tb hard drive (2x1tb western digital black edition) raid 0
    pretty close.
  1. What is the difference between an industrial computer and a normal computer?
    By Apples in forum Controller & Computer Solutions
    Last Post: 09-18-2008, 10:27 PM
  2. What else do you run on your shop/CNC computer. Internet, games????
    By blackhollowmfg in forum Waterjet General Topics
    Last Post: 03-07-2007, 12:28 AM
  3. How cold is to cold for BP Series I CNC
    By jho5820705 in forum Bridgeport / Hardinge Mills
    Last Post: 12-21-2006, 02:13 AM
  4. Shop Bot performance
    By Hack in forum Community Club House
    Last Post: 05-27-2006, 07:33 PM
  5. fast computer as server, slow computer as terminal
    By replicapro in forum Computers / Desktops / Networking
    Last Post: 07-01-2004, 08:05 PM
