587,141 active members*
4,175 visitors online*
Page 4 of 4 234
Results 61 to 66 of 66
  1. #61
    Mar 2017
    1328
    Re: Construction of a CN lathe
    Ok, I think I understand. Solid line at the center is not enough, you want is through all width/height.
  2. #62
    May 2020
    71
    Absolutely.
    The translations cause certain difficulties of understanding sometimes, see often :-)
  3. #63
    Jan 2022
    13
    Hi there
    Has anyone got the G41/ G42 compensation working in the XZ plane? And has the tool table been sorted out for the required parameters?
    It is absolutely no use as a lathe control without as you cannot do any precision profiling and I have a lathe that I converted to Planet CNC that has sat for the last year and a half as without tool radius compensation I cant produce the component shape required without rewriting the program every time I change tool.
    The responses I got from the helpdesk were initially "I believe that you have mix the tool radius compensation and tool length offset.
    Because, the G42/G41 compensation other than in XY plane does not make sense.
    But, you can of course use the G43 or tool compensation which makes sense.
    You can use tool table, you can use tool offset measurement etc.."
    After sending the pages from the linux CNC that demonstrate the problem I got the reply
    "Unfortauintely for now it is only in XY plane. This might be adapted in the future. "
    I would like to know when in future as I am considering changing to a control that does work.
    Regards
  4. #64
    May 2020
    71
    I am also in the same expectation. I should finish the first stage of my tour in a few weeks (no progress during the good weather period, and it is long this year ).
    Planet CNC wants to be among the best and they plan to take this into account. So let's be patient.
    Best ragards
  5. #65
    Dec 2008
    46
    Quote Originally Posted by Steler View Post
    I found some answer,
    The driver documentation is not among the best .
    Attached is the schematic I'm considering. I would like PlantCNC to give its opinion on this double connection and its feasibility.
    best regards
    Hello,
    in the schematic - if I didn't see wrong - the coil of relè for enable, has 3 wires. I have never seen a relè coil with GND pin, but only + and - connected to activation switch.
    Where am I wrong? What did I miss.
  6. #66
    Mar 2024
    31
    If your controller is too old, let me retrofit it with new syntec controller contact me at [email protected]/ +918168294379 (whatsapp)
  7. #67
    May 2020
    71
    I use this type of relay
    For information, I have not yet tested this diagram. For now I only order the turning spindle mode.
Page 4 of 4 234
  1. CNC Lathe Construction question
    By crob09 in forum DIY CNC Router Table Machines
    Last Post: 01-07-2012, 03:49 AM
  2. Construction of Steelie
    By timber_MG in forum CNC Wood Router Project Log
    Last Post: 12-18-2011, 07:45 AM
  3. help in construction!
    By drumbuilder in forum Wood Lathes / Mills
    Last Post: 01-28-2008, 02:43 PM
  4. 80/20 Specs - Lathe Construction
    By Deviant in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 04-06-2005, 04:27 AM
  5. I-Beam construction
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 08-14-2003, 06:18 AM
