587,997 active members*
1,799 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan S280 Turret rotary encoder
Results 1 to 9 of 9
    Oct 2008
    9
    Hi
    I have a lathe Doosan S280 with 8 stations turret.
    The rotary encoder of the turret is broken and needs to be replaced.
    The problem is that there is no manufacturer name or model number on it or in the machine's documentations.
    Can anyone help me getting this information or even better direct me to someone who sell this rotary encoder?
    The local service provider for Doosan is no use.
    Dec 2003
    24220
    As a last resort, if you have the details of the encoder connections on the control end, you may be able to come up with a sub.
    To find out the resolution, remove the encoder cover and if necessary remove the circuit board above the glass disk, the resolution is generally printed on the disk itself.
    Is it a through-hole style or shaft style driven by a coupler?
    Al.
    Albert E.
    Oct 2008
    9
    Thanks for you reply
    The rotary encoder has 5 bits.
    The encoder outputs a binary code using these 5 bits.
    The encoder also has a strobe bit that is used to synchronize the encoder outputs with the machines ladder.
    The machine uses only the first 3 bits for station number and also the 4th bit.
    The code for station no'
    1 is: 1 1 1
    2 is: 1 1 0
    3 is: 1 0 1
    4 is: 1 0 0
    5 is: 0 1 1
    6 is: 0 1 0
    7 is: 0 0 1
    8 is: 0 0 0
    The strobe bit is "0" each time the other bits are stable.
    A photo of the encoder is attached.
    Dec 2003
    24220
    I have come across absolute encoders, but not quite this format.
    I would assume that they have used something off the shelf.
    Much of the Japanese made machinery use Tamagawa products.
    Although the case has the appearance of Heidenhain?
    If it is only 5 bits then due to it being rather coarse resolution, they may use other detection methods than optical?
    Try looking up other Doosan sites if the local rep is not much use.
    Al.
    Albert E.
    The S280N uses this encoder (different machine)
    RAA-60-0010
    Looks similar but not not exact
    Are there any markings on the turret ?
    From what I saw in the manual, sect 8. this machine has a Sauter turret
    either a
    0.5.450.212 (W/O Rotating tools)
    or a
    0.5.460.212 (With Rotating tools)
    Also this thread might be of use
    Oct 2008
    9
    Thanks MisticMonkey,
    The encoder you mentioned does look like it would work.
    Do you have the electrical drawing of the S280N?
    If you do, could you please send me the page of the encoder's connection?
    What is the exact model installed on your machine?
    I'll try to compare your drawing to mine to see if they are the same or not.
    By the way there are no markings on the turret or the encoder.
    The machine was not maintained well enough for years.
    Oct 2009
    30
    If you are still stuck after this long lol, give me your model and serial number and I can get you the right part no problem.
    As a matter of fact i probably have one floating around. Biggest issue here is making sure we have correct pin out for swaping of the encoders, which i can get with small difficulty.
    von007
    Oct 2008
    9
    Thanks Von
    Actually I have a model number that should fit to my machine.
    The machine is: S280#1058
    The encoder model: RAA-67-8-N
    It is 8 positions encoder
    NPN type
    6mm shaft
    Manufacturer: Kwangwoo
    Oct 2009
    30
    No problem
    I have excellent chance of getting this let me check in with my distributor for these today. get back to you tonight.
    von007
    Chips AHOY
  1. doosan 2020 turret alarm
    By sebturbo2000 in forum Daewoo/Doosan
    Last Post: 08-28-2009, 09:03 AM
  2. DOOSAN Z290SM TWIN TURRET LATHE
    By CHAD LAWSON in forum Daewoo/Doosan
    Last Post: 01-22-2009, 03:25 PM
  3. Doosan Z290SMY turret problem
    By alesko05 in forum Daewoo/Doosan
    Last Post: 10-05-2008, 02:04 PM
  4. doosan fanuc 18t turret
    By julio_gyn in forum Fanuc
    Last Post: 05-19-2008, 06:43 PM
  5. Qt20hp Turret Rotary Encoder
    By intermax in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-11-2007, 09:10 AM
