603,958 active members*
2,006 visitors online*
    Dec 2008
    9
    Drive Configuration
    I am a total noob at cnc, i am trying to configure emc2 with a compumotor zeta.
    I have the following specs for zeta
    Code:
    STEP INPUT
    For every step pulse it receives on its step input, the drive will commutate
    the motor to increment rotor position. To send a step pulse to the drive,
    apply a positive voltage to STEP+ with respect to STEP–. The drive registers
    the pulse on the rising edge.
    The input is optically isolated. It may also be differentially driven.
    Step input specifications are:
    Input Current: 6.5 mA minimum
    15 mA maximum
    Input Voltage: 3.5V minimum (min. required for on or high signal)
    5.2V maximum*
    Step Pulse: 200 nanosecond minimum pulse width
    200 nanosecond minimum off time
    2 MHz maximum pulse rate
    Optically Isolated: Yes
    CLOCKWISE AND COUNTERCLOCKWISE (CW & CCW)
    You can convert the ZETA drive’s step and direction inputs into clockwise
    and counterclockwise inputs, for use with a CW/CCW indexer. To do so,
    set DIP Switch 1 – #12 to the ON position. The following changes result:
    Pin # SW1–#12 OFF SW1–#12 ON
    1 Step+ Clockwise+ (CW+)
    14 Step– Clockwise– (CW–)
    2 Direction+ Counterclockwise+ (CCW+)
    15 Direction– Counterclockwise– (CCW–)
    Input specifications are the same as those listed above under Step Input
    and Direction Input. Each positive voltage pulse applied to CW+ with respect
    to CW– causes the drive to commutate the motor and increment
    rotor position in the clockwise direction. Each positive voltage pulse
    applied to CCW+ with respect to CCW– causes the drive to commutate the
    motor and increment rotor position in the negative direction.
    SHUTDOWN INPUT (SD+ & SD-)
    You can use the shutdown input to shutdown, or disable, the ZETA drive.
    To activate shutdown, apply a positive voltage to SD+ with respect to SD–
    when the motor is not moving. During shutdown, the drive turns off
    current to the motor. The current stays off as long as the voltage is maintained
    on the shutdown input.
    When you remove the voltage on the input, shutdown ends. The drive
    restores current to the motor, in the same phase relationship that existed
    before shutdown was invoked.
    The shutdown input may also be differentially driven. Specifications are:
    ➁ Installation 19
    Input Current: 2.5 mA minimum
    30 mA maximum
    13V maximum
    5V maximum reverse voltage
    Active Level: While voltage is applied, current to motor is shut down.
    When voltage is removed, normal operations resume.
    Time: 250 nanosecond minimum width
    FAULT OUTPUT (FLT C & FLT E)
    The ZETA drive can signal, through its fault output, that it has detected a
    fault. Internally, the terminals FLT C and FLT E connect to the open
    collector and open emitter, respectively, of an optically isolated transistor.
    The transistor acts like a switch: it conducts when the drive is functioning
    normally; it does not conduct when any of the following conditions exist.
    ❏ No power is applied to the drive
    ❏ AC line voltage is too low (less than 95VAC)
    ❏ Drive temperature is higher than 55°C (131°F)
    ❏ Drive detects a short circuit in motor or motor cable
    ❏ Motor is not connected
    ❏ Continuity between interlock terminals is broken
    ❏ Shutdown input is active
    Fault output specifications are:
    VCE: 30VDC
    VCESAT: 1 VDC
    Collector Current: 40 mA minimum
    Dissipation: 40 mW maximum
    RESET INPUT
    The reset input provides a means for you to reset the ZETA drive, without
    actually cycling power. To activate the reset input, apply a positive voltage
    to RESET+ with respect to RESET– when the motor is not moving. The reset
    will not be complete until 0.7 seconds after the voltage is removed. A reset
    has the same effect on the drive as cycling power:
    ❏ DIP switch settings are loaded into the drive for configuration.
    ❏ Existing faults are cleared.
    ❏ Current to the motor is turned off while voltage is applied to the reset input.
    ❏ After voltage is removed from the reset input, the drive’s soft start procedure
    will ramp current up to the startup state. The motor will move to the nearest
    pole position.
    ❏ After voltage is removed from the reset input, there will be a 0.7 second
    delay before reset is complete, and normal operations can continue.
    Reset input specifications are:
    30 mA maximum
    13V maximum
    Reset Voltage Pulse: 250 nanosecond minimum pulse width
    Active Level: While voltage is applied, reset occurs.
    Reset Delay: 0.7 second delay until reset is complete, after voltage is
    removed from input.
    From this i gather for EMC2:-
    Axis Drive Type = Stepper
    Step Time ns = 300
    Step Space ns = 300
    Direction Hold ns = 300
    Direction Setup ns = 300
    Is this correct
    Thank you very much
    Best,
    arun
    Feb 2007
    514
    I'm no expert but it looks like it should work if you have the jumper set for step/direction...
    John
    Dec 2008
    9
    Thank you very much john, i will try it out
  1. Spindle configuration
    By Zaryk in forum Mach Mill
    Last Post: 10-07-2008, 03:05 AM
  2. K2 Configuration and Mach 3
    By SPEEDRE in forum K2CNC
    Last Post: 07-07-2008, 02:45 AM
  3. Configuration???
    By derekreuvekamp in forum LinuxCNC (formerly EMC2)
    Last Post: 03-31-2008, 03:25 PM
  4. XP Firewall Configuration...
    By JerryFlyGuy in forum DNC Problems and Solutions
    Last Post: 08-02-2006, 04:34 AM
  5. Comment of different configuration of DIY CNC
    By abasir in forum DIY CNC Router Table Machines
    Last Post: 12-20-2003, 08:22 AM
