603,336 active members*
3,934 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Flash CPR error code 1430 module 151
    Oct 2012
    When Flash CPR is enabled on my co-workers computer, no model renders. I've been looking around for a solution, but the best I've found so far was how to turn on Flash CPR statistics (page 137 of the manual PDF. Unfortunately, "error code 1430 module 151" isn't helping.
    I've got to sideline my search for the moment, but this is a real pain! That machine has a Quadro video card, but I'm not sure of the model number or anything like that, but I'll find out if it matters.
    Jun 2006
    29
    The stock answer on the Gibbs forums is to make sure your video drivers are up-to-date. Failing that, try a re-install.
    Oct 2012
    This is very strange to me, but the issue was solved inadvertently while testing the Quadro fx1700 video card from another computer. When we returned the original card to the computer in question, Windows did something to refresh the original driver installation, and now flash CPR works.
    Thank you for your help!
  1. Replies: 2
    Last Post: 04-10-2025, 06:53 AM
  2. error code 181 from a HPR 260. HELP!
    By rzapo in forum Hypertherm Plasma
    Last Post: 04-25-2024, 10:08 PM
  3. g code error with image to g-code
    By cruzin in forum LinuxCNC (formerly EMC2)
    Last Post: 09-05-2012, 11:34 PM
  4. Error code 104
    By morpwr in forum Haas Mills
    Last Post: 10-27-2011, 03:37 AM
  5. error code 201
    By koppjb in forum Milltronics
    Last Post: 01-14-2010, 06:02 PM
