does anyone now what config to use for the superpid running mach3 through a g540
can get spindle to turn on and off but cannot seem to change the speed of the spindle in mach 3 help please
every thing is configed and wired properly it will do 5000rpm or 30000rpm only
have set pully 4 to 5000 min 30000 max will try changeing to 5000rpm min 10000rpm max a see if it will do 5000 or 10000 if it does work will config pullys 5000min 6000max so on
