http://i59.photobucket.com/albums/g2...uch/wiring.jpg
Hi I bought a couple of these S series Minas drives off ebay. Im about to power them on for a test, there is an inline AC filter and a 3 amp fuse in the plug, should this be sufficent to test the drive without any load? Should I be using the green ground termianls on the drive, you can see them in the picture above. What should I connect them to?
Cheers
Gav
