603,964 active members*
1,835 visitors online*
Page 2 of 2 12
Results 21 to 34 of 34
  1. #21
    Mar 2003
    35494
    Just add one line.
    DoButton( 24 )
    DoButton( 23 )
    DoButton( 22 )
    DoButton( 25 )
    Code "G1 X0 Y0"
    Then do File >Save before you close the Script Editor.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  2. #22
    Sep 2003
    1490
    Just add one line.
    DoButton( 24 )
    DoButton( 23 )
    DoButton( 22 )
    DoButton( 25 )
    Code "G1 X0 Y0"
    I added the below line to the file, and it homes normally, moving only enough to move off of the switches. Then the Y starts moving in the minus direction, so I stopped it after 6".
    Code "G1 X0 Y0"
    Now should I have removed the word "Code" and the parathensis?
  3. #23
    Mar 2003
    35494
    No, if you go to Edit Button Script, the code should look axactly like this.
    DoButton( 24 )
    DoButton( 23 )
    DoButton( 22 )
    DoButton( 25 )
    Code "G1 X0 Y0"
    Copy and paste it in to make sure there are no typos.
    Gerry
  4. #24
    Mar 2003
    35494
    Also, make sure you're Home Offsets for X and Y are set to -.5 in the Homing/Limits screen.
    Gerry
  5. #25
    Mar 2003
    35494
    If it's still not working, try this.
    DoButton( 24 )
    DoButton( 23 )
    DoButton( 22 )
    DoButton( 25 )
    While IsMoving()
    Wend
    Code "G1 X0 Y0"
    Gerry
  6. #26
    May 2006
    1469
    I think you should probably have a G53 in there Gerry.
    Code "G1 G53 X0 Y0"
    Greg
  7. #27
    Sep 2003
    1490
    I changed them both -5 and everything homes and moves just off the switches then the Y moves back onto the switch and gets a reset cond.
    I then changed the -.5 Y to a +.5 Y, and everything homes and moves just off the switches then the X and Y both move 1/2" away from the switch.
    Then I activate soft limits. and now for some reason I cannot jog Y in the - direction with the soft limit on.
    Possibly a soft limit setup issue, I have attached the latest photo of setup showing DRO and soft limits.
    I see I have two more replies, I won't do anything else until I hear back from these results.
    Thank you all for your kind patience. I know this must be frustrating to you,
  8. #28
    Mar 2003
    35494
    Sorry, the moving table got me again. Y axis Home Offset should be 26.5, and change the last line of the script to
    Code "G1 G53 X0 Y26"
    Gerry
  9. #29
    Mar 2003
    35494
    And change the X and Y softlimit min to -.5 again
    Gerry
  10. #30
    Sep 2003
    1490
    Both X and Y back off the home switch and the X if fine withthe soft limits.
    But That old Y doesn't show a soft limit If I run it 3" - then jog it twords home (+) it hits the limit switch without any soft limit warning???
    New photo attached.
  11. #31
    Mar 2003
    35494
    This should do it.
    Y Home Offset 27
    and change the script again to
    Code "G1 G53 X0 Y26.5"
    Gerry
  12. #32
    Sep 2003
    1490
    This should do it.
    Y Home Offset 27
    You are right, it did doo it.
    XYand Z all home and back just off the switches, then X and Y back off another 0.5". And with the Soft Limits activated they all work as they should.
    I have one question I am kind of hesitant to ask though, but I will.
    When it is homed the DRO reads
    X -0.5000
    Y +27.000
    Z +0.000
    Most of the post I have read home at 0,0,0. Mine doesn't because it is a moving table, correct?
    Hager
  13. #33
    Mar 2003
    35494
    Not necessarily because it's a moving table, it just due to the orientation of the machine and where you want it to "park". You could home it at 0,0 and then move it to the current home position to load parts. But it doesn't really matter where it homes to.
    Typically you'll zero the axis in relation to the part you're working on. Or, you can make some type of fence or stop system so you can always load your parts at 0,0 (or anywhere else, actually, but it gets more complicated)
    What's important, is that you understand how we got to where we're at right now. Then we can move forward. Time for me to get some sleep.
    Gerry
  14. #34
    Sep 2003
    1490
    Smile Thank You
    Thanks Gerry,
    I really appreciate you sticking with me through all of this. I did learn a few things and I'm sure the people that followed our rabbit trail learned some too.
    By the way my next macnine will be a movable gantry, this made the final decision. LOL :rainfro:
    Hager
Page 2 of 2 12
  1. How homing and limits work
    By SyilAmerica in forum Syil Products
    Last Post: 11-14-2007, 08:55 AM
  2. How to setup homing in Syil X3
    By albatros62 in forum Syil Products
    Last Post: 11-11-2007, 07:14 AM
  3. Help with limits not working when homing
    By dave70 in forum Mach Mill
    Last Post: 03-22-2007, 05:46 PM
  4. New setup with Mach3 - Limits work, homing doesn't
    By journeyonline in forum Mach Software (ArtSoft software)
    Last Post: 03-22-2007, 03:09 AM
  5. Limits, homing, and relay switches
    By Bloy2004 in forum CNC Machine Related Electronics
    Last Post: 11-25-2003, 12:17 AM
