587,779 active members*
2,868 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > How can I reverse the direction of one motor using turbocnc?
    Sep 2005
    23
    Hello.
    I need some help. One of my cnc router motors is hooked up wrong and thgis makes all the machining make a mirror image. If I machine symetric parts, then this is not a problem, but If I need to engrave some text, I usually make a mirror image already in the cad drawing. But I am tired of doing that. Is there a way in the turbocnc software to change the rotation direction of one of the motors? I looked on the axis config window and could not find anything. I don't want to change the motor wires, because I am not so smart about motors so I rather would like to do it by software means. Can someone point me to a right direction?
    Thank you!
    Jetijs
    Nov 2005
    256
    Change the Direction Pin for that axis. If it is currently "Hi" select "Lo" and vice versa.
    Sep 2005
    23
    Thank you, my friend
    This is just what I needed
  1. Reverse Stepper Direction, Wiring Questions...
    By Patrick_M in forum Hobbycnc (Products)
    Last Post: 10-02-2008, 07:36 PM
  2. Reverse direction?
    By HakBot in forum G-Code Programing
    Last Post: 11-19-2007, 11:30 PM
  3. Turbocnc direction signal help?
    By giggler in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-17-2007, 06:12 PM
  4. Reverse axis direction?
    By saturnnights in forum Machines running Mach Software
    Last Post: 03-29-2006, 03:40 AM
  5. Replies: 0
    Last Post: 11-01-2005, 03:51 AM
