587,158 active members*
2,906 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > How to machine an outside fillet edge?
Results 1 to 7 of 7
    Oct 2015
    5
    I am using fusion360 and have an 1/8th inch fillet on the outside edge to top edge of the part. I don't have a round-over bit and am hoping to step the edge of this and sand it smooth (wood). I am having trouble finding a good way to do this. I have tried to scallop it and it doesn't work that well.
    -Zack-
    Jun 2014
    777
    Quote Originally Posted by MSF_REAPER View Post
    -Zack-
    A 3D contour using only the touch/avoid surfaces selection, no other selections required I.e contour profiles or model, selecting the edge with the touch/avoid selection and ticking touch surface checkbox using a ball nose may do it.
    This is only a guess tho as it would be my first approach without a round over bit.
    Oct 2015
    5
    Re: How to machine an outside fillet edge?
    whoops I am thinking ramp with a small stepdown is my best option
    Oct 2015
    5
    Your reply didn't load before I wrote mine. I may try your way and see. The biggest issue I had with using a ball nose is that it scooped instead of cupped too much.
    Jun 2014
    777
    Let me know how it goes.
    Jun 2006
    629
    For the cost of a router bit, get a 1/8 corner rounding bit.
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
    Jun 2014
    777
    How did it go?
  1. Fillet Edge issues
    By JMBush01 in forum Rhino 3D
    Last Post: 09-09-2013, 02:15 PM
  2. fillet edge when surface is not wide enough
    By arjena in forum Rhino 3D
    Last Post: 09-05-2013, 08:28 PM
  3. Mastercam 3D Fillet (Round Edge)
    By welen in forum Mastercam
    Last Post: 11-30-2010, 09:25 PM
  4. Fillet Edge Question
    By ChuckInCR in forum Rhino 3D
    Last Post: 04-18-2008, 10:27 PM
  5. How to machine a fillet?
    By hxczach in forum Mastercam
    Last Post: 04-03-2008, 01:02 AM
